Anyone have one so equipped? My 2019 owners manual lists no tow rating with the manual transmission. We put an OEM receiver on our 6spd manual Compass. Mostly for cargo rack purposes.
I think the only reason they don't give the manual transmissions an official tow rating in the owner's manual is to avoid the liability of poorly-skilled drivers burning out their clutches.Any stick is better than an auto!!
Short shift linkage? Darn, thought I'd be the 1st to do thatYes, clutch delay/dampner devices are dumb. They're there to help people who are poorly skilled, at the expense of the clutch anyway.
I've been thinking about things like getting rid of that, and adding a Pedal Commander to make the engine respond like it should. Would make the car feel tighter. I put a short shift link in it a while back, that helped too.
Factory tow package? Or did you add it yourself?I have a 6sp manual and occasionally hitch up a small trailer. Handy in a pinch. Haven't had any issues.
Ha. You can claim first I don't mind. I just used a little link that goes on the transmission itself. Was cheap and pretty easy. I think we made it to 2000 miles before "mods."Short shift linkage? Darn, thought I'd be the 1st to do that. I am planning on removing the delay valve soon along with the linkage. Just getting a few different mods lined up and then taking a weekend to knock them all out
Did you happen to get yours from Modern Performance? I was looking at one made for the Dart that I THINK should work for us.Factory tow package? Or did you add it yourself?
What the heck is this cluch delay valve? And is it the reason I can't drive this car smoothly after 45 years of driving sick? How do I disable it?I recently learned our manuals have a clutch delay valve. I plan on removing this soon to see if I get any better clutch actuation. Theoretically should help prolong the clutch life if you're worried about that.
Most likely, yes. It's a valve in the hydraulic line to the slave cylinder. It's supposed to help new manual drivers by not allowing you to dump the clutch. I'm sure it does help them some. But experienced drivers who expect to feel the clutch and have it react a certain way, it messes with that and can give a jerky release.What the heck is this cluch delay valve? And is it the reason I can't drive this car smoothly after 45 years of driving sick? How do I disable it?
YesAnd is it the reason I can't drive this car smoothly after 45 years of driving sick?
samesI have a 2018 4WD, with MT6 and factory trailer tow package. The tow package also got you a full sized spare tire.
