So, I had a rock bust out my right side lens. The light still works which is fine, but I'd like to replace. Do you know if I could buy just the lamp, or should I get the housing and lamp - meaning will tabs break off or the housing itself get messed up when taking out?
Lamp
https://www.ebay.com/itm/NEW-REPLACEMENT-FOG-LIGHT-LAMP-FOR-CHEROKEE-COMPASS-ProMaster-68353533AA/222867127793?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
VS.
Entire Assy
https://www.ebay.com/itm/For-17-18-Jeep-Compass-Factory-Style-Front-Left-Right-Fog-Light-Fog-Lamp/302901124547?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
Thank you!!!
I would just buy the lamp. The way to remove and install it is behind the wheel well liner, you don't have to touch the bezel/housing. What year is your jeep compass?
i am installing oem fog lights on my 2019 compass that doesnt currently have light in place on the removeable cover i have the bezel insert and trim lights coming in today, i ordered the new dash switch with fog lamp button is there anything else i need to do since there is already factory wiring in place to plug them into?
You need to activate it using Alfa-OBD or an official scanner capable of changing configuration. You would also need to install security bypass module if there is a security module.
