Hey guys iv been looking for the right or the best way to run my wires for the back up camera to my head unit. Any suggestions? Thanks
This is how i did it.
1. i removed the plastic cover off of the inside of the tailgate
2. saw 2 screws inside of the tailgate holding the handle up on the other side of the gate. un-did them.
3. drilled a small hole on the part you just unscrewed, its plastic very easy to do. you drill a hole just large enough for the cable.
4. ran the cable though the rubber housing that connects the tailgate to the car's frame. I had to use a coat hanger and made a hook at the end of it to push the wires though.
5. My memory is foggy here, i remember running them down some how to the bottom of the car. im sure you can figure it out.
6. i ran the cable from the back to the front of the car and hid the cable were the carpet meets the plastic door cover on the floor. I just pushed the cable in between there.
7. ran the cable inside the dash from the driver side to the center of the dash.
hope that helps.. its alot of work hope you are ready :D
Haha ya iv got a friend that has done a lot of installs. He said won't be.to much of a problem but just kind of getting an idea of what to look for but yes it help me better visualize it. one more question.
