I am changing my drivers side front control arm tomorrow so I was looking around for torque specs. I found torque specs for the ball joint pinch bolt and rear mounting bolt but nothing on the front mounting bolt. Just looking for it so I can get this done and then see what else comes up with after (I did the inner tie rods then cuz they were tight the control arm showed its loosen).
Front control arm mounting bolt torque spec?:dunno:
Thanx
Front LCA (Lower Control Arms)
Pivot bolts 135 ft. lbs.
for caliber srt4 so it's almost same frame and parts suspension.
