Does anyone know is there a fuse box in the interior? I have a 2018 model and can’t find one anywhere. Really want to hardwire a dashcam. Do I have to run the wire to the engine fuse box? Can’t find a single video on YouTube. Do compass drivers just not use dashcams? I did try removing the plastic on the side of drivers side and nothing there. So odd.
Interior Fuses
The interior fuse panel is located in the passenger compartment
on the left side dash panel under the instrument
panel.
Cavity Blade Fuse Description
F31 7.5 Amp Brown Occupant Restraint Controller
F33 20 Amp Yellow Window Motor Passenger
F34 20 Amp Yellow Window Motor Driver
F36 20 Amp Yellow Intrussion Module/Siren, Radio, UCI/USB Port, VSU,
Climate Control, Electronic Steering Lock, Power Folding
Mirrors
F37 10 Amp Red Instrument Panel Cluster, Drivetrain Control Module,
Adaptive Cruise, ECC (HVAC) Blower
F38 20 Amp Yellow Door Lock/Unlock
F42 7.5 Amp Brown Brake System Module, Electric Power Steering
F43 20 Amp Yellow Washer Pump Front And Rear
F47 20 Amp Yellow Rear Left Window Lifter
F48 20 Amp Yellow Rear Right Window Lifter
F49 7.5 Amp Brown Park Assist, Blind Spot, Voltage Stabilizer, Humidity Sensor,
Sunroof, Electronic Steering Lock, Temp Sense, Mirror,
Heated Seats, Light And Rain Sensor
F50 7.5 Amp Brown Occupant Restraint Controller
F51 7.5 Amp Brown Electronic Climate Control, Occupant Classification, Rear
View Camera, Climate Control, Headlamp Leveling, Terrain
Select, Heated Rear Window, Trailer Tow, Haptic
Lane Departure
F53 7.5 Amp Brown Keyless Ignition Node Module, Electric Park Brake, RF
Hub, Cluster
F94 15 Amp Blue ECC (HVAC) Blower, Lumbar Adjust Driver Seat, Power
Outlets
