41 - 60 of 100 Posts
8 Pin Information
CavCircuitGaugeColorFunction
1L441.0WH/BGRIGHT LOW BEAM DRIVER
1L3041.0OG/WHRIGHT HID LAMP DRIVER
2L341.0WH/GYRIGHT HIGH BEAM DRIVER
3Z9061.0BKGROUND
4N00NANO CONNECT
5L1180.50BG/OGRIGHT FRONT PARK LAMP DRIVER
6N00NANO CONNECT
7Z9061.0BKGROUND
8F9440.50PK/GNFUSED IGNITION
8L1440.50BG/OGRIGHT SIDE MARKER CONTROL
9L1330.50WH/YEHEADLAMP LEVEL MOTOR SIGNAL
9L1500.50BG/GYLED CONTROL SIGNAL 2
10Z9061.0BKGROUND
This is what I was looking for. Thanks a ton.
So basically it seems just tapping the side marker positive and adding couple of grounds would do the trick.
Discussion Starter #42
Well I just need a video or write up on how to do those types of wiring blocks. I really don't want to hack on the OEM harness if I don't have to... I mean I have lifetime warranty soooo ripping things apart that I can't put back together is kinda not what I want to do...
Rather make an adapter if possible...
The best and safe option is to buy couple of male and female connectors (68394501AA and 68137859AA) and build your own adapters which will you put between original harness and Headlights. Jeep connectors are expensive ( around $100 each x 4 = 400) but I found much cheaper replacement for $ 6 each x 4 = 24 :)
And what is that cheap option, if you don't mind sharing here.
yes it should be Pin #9
cheaper option for connectors: MOUSER.CA or MOUSER.COM
male connector #649-54241004 - CAD 6.35,-
female connector #649-54241030 - CAD 6.50,-
Discussion Starter #49
I just ordered these connectors so I should to know soon how it fit.
Keep us in the loop and maybe pic by pic? To help us noobs... Cheap is the only way I can go at this point I. $650 deep on these bad boys and no where to sell them 😑
Discussion Starter #60
Halogen Premium
I have no idea what I am looking at but I am guessing halogen premium has the right pins and power to make the eBay HID aftermarkets work but not the OEM headlights.
I am guessing I have a base set up and i need to adapt to halogen premium set up. This is just a guess. Maybe @ziggy could figure out these diagrams.
I will wait patiently till the smarter people help lol 😂
