Compass 2019 Latitude
Auto Start/stop system failing due to hood open error, there is an easy to see plastic switch in the top of the grill that i replace due to obvious damage, but the error still show up
that's why i think there is another switch that i can't find. The plastic switch that i replace activates a red error sign (a car with hood open), the switch that i can't find activates a text error message in the screen of auto start/stop system
obviously i prefer the auto start/stop working fine
Is there a second switch or is something else? Can someone help on this?
thanks
I looked all over my hood and engine area and don't see a second switch on my 2019 Compass Sport. There are other reasons that the Stop/Start turns itself off...some posters have had problems with the small battery for this system. What does the text error message say exactly?
Another idea...check that your 2 battery monitoring connectors are plugged in securely (red circles in picture).
When you replaced the switch did you also replace the striker plate?
There is a TSB related to the start/stop system and the striker plate, you can see the new style striker plate in this thread: TSB 08-160-18 ESS Error (the new style is on the left in the picture).
Interesting....perhaps holding down the switch with the hood open and seeing if the message goes away would confirm this is the cause.
Thank you for your suggestions, finally i found that second switch, is part of the hood latch, is a mechanical micro-switch (that in my opinion look pretty weak for the job).
manually pushing both switches was confirmed this is the reason for the auto start/stop failing. i can't found the switch by itself and ordered the hole latch which is no expensive ($34 dlls),
i will keep you posted
thanks
eBay item number:
333208413541
Thanks for following up with your post and letting us know.
