1 - 10 of 10 Posts
How many years old can a new tire you buy at the tire shop be? Considering we are in October 2018, can you still buy new tires produced in say 2015?
depends on the shop, tire size ect
i wouldnt buy a 3 year old tire. 5-7 years is standard life of a tire iirc
of course thats if you dont wear them out first
Now the other question is, how many years of use is the maximum for a tire considering a standard use of 10.000 miles/year?
(I am asking for a 225/65/R17, or 225/60/R17 stock on a Compass)
check the manufacturer, most say 5-7 years or the tread wear life
people that ride motorcycles are very concerned with tire age.
dryrot is not always noticed.
i usually hit tread wear way before age (30k miles a year)
so if you buy a 3 year old tire rated at 60k and drive 10k a year
it may start dry rotting before the tread wears out
So you mean that usually tires are rated at 60k therefore if you drive 10k/year which is the most common, they will last 6 years maximum. If you also say that the rubber on the tires can last a maximum of 7 years (you said 5-7 years), then you can only buy 1 year old maximum tires, is that right?
pretty much
if you have ever owned a trailer, you really see tires rotting before the tread is gone
its best to buy as new a tire as possible.
there is a datecode on the sidewall
pretty much
Ok, but the question is how much new as possible? Is it 1 year old ok? Is it 2 years old still ok?...
If a retailer is trying to sell 2 year old tires as 'new' I would be suspicious. You should at least get them at a discount ie older tire = less value.
Roughly speaking tires should be discarded at 6 years even if they still have tread. So if you were considering 2 year old tires that have never been used and were stored properly, they should cost 2/3 (4/6) of new price.
When you buy a used vehicle you should also be aware of tire age. The vehicle itself may be a year older that it's model year (check for date of manufacture) and the tires would be older than that. Example you could buy a used 2017 that has the original tires, dating from 2016 or 15. Again, be aware of the actual value and don't overpay.
Discussion Starter #9
But if you buy 2 year old tires, then you only have 4 years of usage of the tires. Then you will have to get rid of them at year 4 even though the tread is most likely still ok? (Considering a standard usage of 10,000 miles/year)
1 - 10 of 10 Posts
