1 - 20 of 27 Posts
Thanks for the tutorial Germaneon! After watching your video I ordered the same bulbs you have, but in white. Installation took about 10 minutes for all 6 bulbs, and that is only because I had a hard time getting one of the back seat light covers off. What a difference in light output! Great and simple 1st upgrade to my week old Compass.
  • Like
Reactions: Germaneon
Discussion Starter · #4 ·
Finally got around to replacing mine. They look so much better. Thanks for the video and listing the bulbs.
Since I had four left, I went ahead and replaced the bulb in the glovebox as well. Also a large improvement. It is a little tricky switching that one out due to the tight space, but is completely possible.
Discussion Starter · #12 ·
It's rather tight behind the flags, I removed the trim as shown in the image below (no need to remove it completely, just wide enough to get the LED behind.
Bought two additional small sockets for the LED and fixed the sockets with two sided adhesive tape. The narrow space between trim and vehicle's body when the trim is fastened again, also helps to keep it in place.
The power comes from the two other lamps in the trunk below.
Oh I see u added the lights, from the original post it sounded that the sockets where there and just needed bulbs. But I see what you did now. LOL
Made a video about how to replace the dull stock interior lights by LED
https://www.youtube.com/watch?v=heqY3-yjF7s
Thanks for the video tutorial, very informative! However, while I was trying to pry out the plastic cover for the rear seat lights, the entire housing popped into the headliner. Any ideas of how to get this seated correctly? Or will the dealer need to do this?
Hello Germaneon,
in your video tutorial about changing LED bulbs in interier lights I saw that you have a short roof antena. Could you send me the type this antena, ev. where can I buy it?
Thank´s for your info!
Petr Liska
Discussion Starter · #19 ·
Hello Germaneon,
Petr Liska
Bought it from German amazon page, here's the link:
+++ 3,3cm Antenne nur für Jeep Compass ab Baujahr 08/2017 + Fiat / Abarth Spider 124 + Mazda MX-5 (4. Generation ab 2017), 2,27cm unterer Durchmesser https://www.amazon.de/dp/B076F13VQ1/ref=cm_sw_r_cp_apap_kk1ZTk8SjFT99
1 - 20 of 27 Posts
