thanks
its probably a 5 inch total difference the tires are much bigger and much better then OEM tires. I go on the beach out here on Long Island. Tyler wow yours is awesome love the wench but I'm happy with mine lol. I just wanted that little extra tire for the sand
it's not 5" higher than stock, the way you get lift from tires is take the original factory tire size which is 28" and find the difference between that and the new tires size. 235/65/17 = 29.1"
29.1 - 28.0 = 1.1" / 2 = .55" you would have gained .55" of lift from just the tires.
2.125 + .55 = 2.67" of lift vs the factory height.
AT/3's are great, they have worked in everything I've gone through snow mud ice & sand,if you are doing a lot of sand driving make sure you air down a bit as that helps a lot.
