1 - 1 of 1 Posts
Hey all, I am an experienced mechanic in many fields, I currently work on diesel tractors but have worked on cars and motorcycles as well.... that being said, this one is stumping me.
I have a 2011 Compass limited 2.4L 130k miles. I had it reflashed last year in October for the recall. In November the crank position sensor went bad, 2 months ago the intake runner motor, and now this Cam position sensor issue.
I have already replaced both cam position sensors and checked the wire harness with a multimeter from the Cam position sensor to the PCM. I tried wiggling the wires to see if my resistance change.... not a bit.
I replaced the battery terminals, checked all my grounds, charging system etc. This code returns.
I have found it happens after the engine warms up a little, it happens a few times, I pull over, clear the codes, start the car, and it comes back.... then all the sudden it will run fine for a few hours of driving.
I am baffled. The only thing I haven't checked is the tone wheel on the cam.
Let me know what you think.
Thanks,
Mike
1 - 1 of 1 Posts
