Question
Im a mechanic and know usually in a shop a lot of bolts are not torqued. Like tie rod ends, ball joint nuts and suspension parts. But when I do my car I take the extra time to try to torque bolts down.
So my question is: I'm doing both of my inner tie rods this weekend and can't find the tightening torque spec for the inners. I found outer @ 80 ft-lbs. Anyone know what it is?
Check this: (from the repair manual of the 07-09 Compass)
FRONT SUSPENSION FASTENER TORQUE
DESCRIPTION
N·m
Ft. Lbs.
In. Lbs.
Hub Nut
245
181
Lower Ball Joint Stud Pinch Bolt
82
60
Lower Control Arm Front Pivot Bolt
183
135
Lower Control Arm Rear Pivot Bolt
183
135
Stabilizer Bar Cushion Retainer Screws
30
22
Stabilizer Bar Link Nuts
58
43
Strut Clevis-to-Knuckle Nuts
84
62
Strut Rod Nut
60
44
Strut-to-Tower Nuts
48
35
230
Tie Rod Adjuster Jam Nut
75
55
Tie Rod End-to-Knuckle Nut
132
97
Wheel Mounting (Lug) Nuts
135
100
REAR SUSPENSION FASTENER TORQUE
DESCRIPTION
N·m
Ft. Lbs.
In. Lbs.
Brake Flex Hose Trailing Link Mounting Nut
15
11
Brake Flex Hose Trailing Link Mounting Screw
23
17
Crossmember Stay Brace Mounting screws
25
18
221
Hub And Bearing Mounting Bolts
105
77
Hub Nut
245
181
Lower Control Arm Trailing Link Bolt Nut
95
70
Lower Control Arm Crossmember Mounting Bolt Nut
95
70
Shock Assembly Lower Mounting Bolt Nut
99
73
Shock Assembly Upper Mounting Nuts
48
35
Shock Rod Nut
24
18
34
25
Stabilizer Link Mounting Nuts
58
43
Toe Link Trailing Link Mounting Bolt
95
70
Toe Link Cam Bolt Nut
35
26
Trailing Link Body Mounting Bolts
110
81
Upper Control Arm Trailing Link Bolt Nut
95
70
Upper Control Arm Crossmember Mounting Bolt
95
70
135
100
I hope this helps.
Regards,
William
:wjeep:
Thanx. I'm looking for the inner tie rod to the steering rack. Also I have found different numbers for the outer to the knuckle 55, 65 & 97.
