1 - 20 of 22 Posts
Looks good! Much better than stock.
Yup! hehehe. i also installed a 3rd party mod to the navi so i can type in destinations while driving in (the passenger would do this of course). :)
photos are down due to hurricane irene. It will be a couple of days before the power comes back.
awesome install. now i know how to remove the face plate.
THANKS!
glad i could help. what were you thinking of installing in yours?
helpp
is the radio antennae adapter required? I'm trying to install a pioneer into my 2011 compass..and the place around me only has 2010 dash kit and wiring harness.. are these compatible?
chansharp said:
is the radio antenna adapter required?
it is required for the aftermarket radios (or you wont be able to connect your jeep's antenna to the radio without it). Just buy it off of ebay its cheap.
I'm not sure do you have a model number for the wiring harness and the dash kit?
what model of pioneer radio are you installing?
lol i see you posted here and at the other site. next time just post in one place ill get your message. :D
Lol my bad.. i saw that one was older than the other so i didn't know if you had moved sites.. and idk they model numbers for the harness and kit. the store just said they had them to fit on the 2010. and they didn't know if the 2011 were compatible. Do you know which model numbers are compatible? and for the antennae adapter as well?
Discussion Starter #10
well i did install the same radio in my 08 compass... so i'd say you will be fine with the wiring harness. I just looked at a photo of the dashboard of the the 2010 compass and they "look" exactly the same. So you SHOULD be fine with the 2010 dash kit too. I dont have a model number for the antenna adapter.
Discussion Starter #13
Discussion Starter #15
i'll take a pic and upload it later tonight
Where did u run the gps antenna, i have heard that some windows do not allow sat signal in. srry old post...newbs!!!
i mounted mine in the factory location under the dash. Behind the radio above the air vents. It will work through the plastic and windshield. the factory antenna is mounted on a flat panel under the dash in the same area.
I get the rest of my install equiptment today and will start tearing into it. I will look around for the spot refer to, thanks for the info. Also pics would help w4rh4wk thanks a ton. Another question if i may, i have an xm tuner i need to mount somewhere...there might be some room behind the dash and i will search a bit, but if u guys have some suggestions they are very welcome......EXXXCITTED..srry..lol
i slid my antenna between the two top air vents, it flattens out behind them youll feel the spot. If you have a DD radio youre going to have to cut the lower bracket out of the dash to fit the new radio. If y ou have the power package with a 110 inverter the inverter is under the radio. I slid my XM box to the left bhind the AC button area. if you take the plug off your stock sirius antenna (if you had sirius) you can use the same factory antenna for the XM, thats what i did. They are both mini BNC connectors.
once you get the lower bracket off you get lots of free wire room as well. youll see once y ou get in there.
Discussion Starter #20
Hi can you send me the pictures idk why but I can't see them on this thread. Thx I'll appreciate it your help.
links updated see original post
1 - 20 of 22 Posts
