My Jeep Compass power inverter the 115v one in the middle of the driver and passenger will not reset. Any suggestions on how to replace it...
First of all - diagnostic help (from the 2014 service manual)
DIAGNOSIS AND TESTING - INVERTER MODULE
WARNING: Disable the airbag system before attempting any steering wheel, steering column, seat belt tensioner, side airbag or instrument panel component diagnosis or service. Disconnect and isolate the negative battery (ground) cable. Wait two minutes for the airbag system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the airbag system. Failure to follow these instructions may result in accidental airbag deployment and possible serious or fatal injury.
110 VOLT POWER OUTLET DIAGNOSIS
NO POWER AT THE 110 VOLT POWER OUTLET
X. POSSIBLE CAUSE
X. CORRECTION
1. Fuse inoperative.
1. Check Totally Integrated Power Module (TIPM) fuse number 37. Replace fuse, if required.
2. Power outlet connector damaged.
2. Check for loose or corroded power outlet connector. Repair, if required.
3. Inverter module connector damaged.
3. Check for loose or corroded inverter module connector. Repair, if required.
4. Wiring damaged.
4. Check for shorted or open wires. Repair wiring, if required.
5. Inverter module ground damaged.
5. Check for continuity between the inverter module and a known good ground. There should be continuity. Repair ground, if required.
6. Power outlet inoperative.
6. Replace the power outlet.
7. Inverter module inoperative.
7. Replace the inverter module.
Power module inverter removal
WARNING: Disable the airbag system before attempting any steering wheel, steering column or instrument panel component diagnosis or service. Disconnect and isolate the negative battery (ground) cable, then wait two minutes for the airbag system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the airbag system. Failure to follow these instructions may result in accidental airbag deployment and possible serious or fatal injury.
Disconnect and isolate the negative battery cable.
Remove the shift bezel.
Remove the center bezel from the instrument panel.
Remove the fasteners from the mounting brackets of the inverter module.
Disconnect the electrical connectors and remove the inverter module.
Did you figure out the problem yet?
NOTE: This only works when the engine is running! I am not sure (haven't bothered to test it) but if its drawing power without anything plugged in or not. I've only used mine for cell phone charge but prefer to use a 12V charger for the phone so its not been used for at least a year or more. LOL
Inverters can draw a lot of amps and it not practical to use that for something running at 5VDC for example.
I was able to remove the center console and remove the 115v inverter. I am now in search of a replacement part for 115v inverter... Doesn't have to be from Chrysler... Anyone have a good place to buy one under 40 bucks or a good trustable site for replacement parts for this part.
2007 Jeep Compass
Did you verify it failed. There are many 150watt inverters (bigger and smaller out there). Its a question whether they'd fit with the system. My experience is that the OEM is highly proprietary in connecting anything to the factory electrics.
Auto wrecker for the best bet of a module.
is that a site or place because where I am in the state of North Jersey we do not have actual car part yards that are open to the public but, we have a ton of scrap metal yards.
