· Registered
I recently purchased a 2011 Jeep Compass latitude and when I took it for an inspection I was informed the frame was almost completely rotted through. I did see where the warranty had been extended for 10 years as this was a common problem on this year. I also live in WV which is a state that was included, but I’m not the original owner. Is there any help available for this issue?
· Registered
It is only a $200 part and you can do it in your driveway but on a lift with air tools would make life easier
· Administrator
The extended warranty was 10 years for the original owner. You may miss out on two counts. However, the repair is certainly possible and not outrageously expensive -- not like an engine or a transmission. A good body shop can fix your frame, no problem.
You may be a tad optimistic. I'd add $1000 to your figure. I've done plenty of rust repair, mostly cutting and patching holes in the body or fenders. Personally I would not attempt to fix a frame myself because there's too much other stuff involved.
