Anyone else experienced this issue, temp drops to below freezing, and the car is not run for 2 days or more, the battery voltage drops to below 11 volts. So won't start, but the battery on charge for 1 hour fires up with no issues and runs, alternator charges the battery fine.
Yep, pretty common issue actually. I try to keep a trickle charger on mine when I know it will be sitting a while. If you complain enough they may replace the battery but with another equally crappy one most likely.
Thanks for the reply, any recommendation of what to replace it with?
