Welcome to Compass. I think that there a a few who have the new ones that may be able to help.
Same thing is happening to me. It was fine until I hit about 11,000 miles then it goes dim off and on.Hi Everyone, My Uconnect system display and dashboard display are at about a 1/10 brightness in daylight. It happened for the first time today. Brightness was fine in the dark garage with headlights on. I have looked at settings, but even if I change the display to manual, the brightness section does not allow me to adjust daytime brightness (that option is dimmed out).
Thanks for any help.
Hi Jake,Hey all,
I had this happen to me today. I disconnected both batteries and let it sit for about 5 minutes. When I reconnected everything, the display brightness was back to normal. I’d tried the factory reset of Uconnect first but that didn’t do anything so as usual “turn it off and on again” seems to work 🤣.
Jake
‘22 Trailhawk
Hello optivisor14,Same thing is happening to me. It was fine until I hit about 11,000 miles then it goes dim off and on.
I took mine to the dealership was told “Jeep is aware and working on it “ and told to call back in a monthI am bringing in the Jeep to the deale tomorrow. It seems that the screens are stuck on nightmode, but I haven't found a way to change that. I'm guessing the dealer may just do a hard reset. I'll let you know.
Hi pwirtz7969,my wife's jeep compass 2022 will not let me adjust center cluster display. control panel will not let me go into daylight mode under manual adjust. only night time mode will only let me adjust left and right screen settings. need to see my speedometer and how much gas i have. ready to turn this f***er in. and yes i have tried the left knobs underneath the column. riding around blind is not cool.
Hi sherrymccrossin,I took mine to the dealership was told “Jeep is aware and working on it “ and told to call back in a month
Yep I’m also having this exact issue. Just recently hit 11,000 miles. Very frustrating.Hi Everyone, My Uconnect system display and dashboard display are at about a 1/10 brightness in daylight. It happened for the first time today. Brightness was fine in the dark garage with headlights on. I have looked at settings, but even if I change the display to manual, the brightness section does not allow me to adjust daytime brightness (that option is dimmed out).
Hi tjrivera,Yep I’m also having this exact issue. Just recently hit 11,000 miles. Very frustrating.
