Jeep Compass 2011 2.4L 2WD Basic module will not start. I have my engine light on as well as my ETC light. The ETC light goes away if I shift through the gears but the Engine light stays on and blinks. I was able to turn my key to get the codes P0622 and P0855. I tried jumping and that didnt work. I replaced the battery and checked all the fuses and could not find anything wrong. I have read online that it could be a short in the alternators cabling or it could be a bad EMC. or the plugs on the EMC are damaged and need replaced. I live in western michigan on a dirt road. So plenty of salt and dirt get into my jeep. The engine will crank over all day if I held it but wont start. lights and everything work. This happened about a week ago and I read online it could be my gas cap? I had a gas cap open message so I opened my gas cap closed it and hit my battery a few times with a wrench (out of anger I was late for work) and it started right up. I tried that as well this time and no luck. Let me know if this is an easy fix for my dad and i or if this is a dealership trip? Dads an old school mechanic. so as long as its not computer related he can fix it.
I would try checking for a spark first. Because it uses a coil pack, take off the engine cover, take the coil out and the plug, ground the plug to the head, and try cranking it to see if it sparks.
hitting the battery and it started, really ? sure the battery is good it may show 12 volts but no amperage behind it,, bad cells,, try a load tester on the battery to confirm its good. there is nothing like chasing down a electrical problem and finding out it was the battery all along. then check for loose connections or a bad wire or ground.
check to see it a wire has pulled part way out of a plug. or corrosion in a plug.
hope you find it.
