egeniius said:
I just got a Steel Blue 08 and I am having this same problem.
I can turn on and off the flash-lights feature using the key fob but cannot get it to disable the honk on lock.
Did anyone get this resolved, and how?
Thanks in advance.
D
I haven't tried it but the manual states...
"To Lock the Doors and Liftgate...
Press and release the LOCK button on the transmitter to
lock all doors. The turn signal lights will flash and the
horn will chip once to acknowledge the lock signal. If
desired, the “Sound Horn On Lock” feature can be
turned on or off. On electronic vehicle information center
(EVIC) equipped vehicles refer to “Personal Settings” in
the “Electronic Vehicle Information Center (EVIC)” section
of this manual. On non EVIC – equipped vehicles
perform the following steps:
1. Press the LOCK button for 4 to 10 seconds.
2. While the LOCK button is pressed (after 4 seconds),
press the PANIC button. Release both buttons.
The “Sound Horn On Lock” and “Flash Lamps With
Lock” feature can be reactivated by repeating this procedure."
Hope this helps.
