1 - 9 of 9 Posts
When I shut the engine down and open the door, the chime starts and stops only when I close the door. The remote does not work at all. It is similar to what happens when the key is left in ignition.
I took it to Jeep service, and they could not find what was wrong though they were willing to keep it for a day, check it manually and charge me $1000 for it.
I took it to another shop that had a computer to get a second opinion, but they could not find what was wrong either.
Any advice?
First welcome to the forum, glad you found us........and as for your question :
Tell the first dealer to go take a hike........to charge $1000 for what ??? this one should br classified as a Stealership..............tell us more about the year, model...etc
Welcome to the forum! Honestly, that has me puzzled.....so, engine off, key out of the ignition you open the door, step out, close the door and then the chime? I read your post a couple times, but seems something is crossed somewhere, as it works, only opposite from what it is supposed to.....and your key fob doesn't work, either?
Thank you guys!
My Jeep Compass is 2007 year (January 2007), Sport model. I have 93000 km on it (58000 miles). Except for regular maintenance never had any problems with it. Tires started making some noise after 50000 km (31000 miles), but since they are great for Canadian winter drive I do not mind it.
The first and only real issue I had was this computer /sensor problem. To clarify: I shut the engine, take the key out of ignition, and open driver's door and the chiming starts. I can use power locks, but not remote. The alarm works fine.
Conclusion: everything works fine except for the remote!
Hi there Dragon,
I am having the same problems with my keyless entry.
I have a 2009 Jeep Compass Sport (also bought in Canada - Quebec)
Mine is still under warranty, and I have moved to the US. I just picked my car up from the dealership here, and they had it for a week - and could NOT figure out what was wrong with it. They told me to take it back up to Canada, and see if the dealership that I bought it from could figure out what was wrong. I am still under warranty (luckily) but even if you paid to fix it, it looks like even the manufacturing engineers are stumped.
Did you get to resolve this issue yet? If you did would you mind telling me in details what they had to fix??
Thanks
Also Dragon - did you have any leaking problems??
My car was leaking water and then the computer shot the bed.
yay Jeep.
No luck yet!
Hello MM44,
I did not resolve my key-less entry problem yet and chiming is driving me nuts. I did try two more services, but they could not do anything about it.
On the other hand, I really like my Compass and everything except afore mentioned works fine. It is great in winter and mileage is good, too.
My opinion is that you should push Jeep service to manually take out and replace all of the relevant modules until they find the faulty one. That is what they started doing for me, but since my warranty expired I did not feel like paying $$$ just so they can tell me what is wrong. I read somewhere that it might be necessary to replace complete alarm and key-less entry unit
I had no leaks on my Compass.
Good luck and do not let Jeep off the hook - they have to fix it for you while you are under warranty.
My guess its the TPIM. Everything seams to got through it or is controlled by it via info from the PCM. They're not cheap from what I hear. I've had two new ones installed so far and that make it the 3rd the car has seen. They're troublesome.
If its under warranty then why haven't they replaced what controls it. EG TPIM and/or what ever and see if it goes away. Warranty is North American. Next thing they'll tell you its normal and not do anything either. That the line I get half the time.
I have the same problem with my 2008 Compass. When I shut the engine off, remove the key and open the door, the chime starts and stops only when I close the door. The remote does not work at all nor does the lock console switch (as is it still thinks the key is in) until something 'times out' about 60 seconds. Then the lock switch on the console works. Key fob does not work. This is intermittent problem. Although lately it doesn't work most of the time.
1 - 9 of 9 Posts
