AHA! Went down to the mechanic, he got a pair of needle nose pliers, twisted the black socket casing until the tabs were aligned, and the bulb just pulls right out. Not sure if its the same on yours Skyeye, but the bulb comes out easily once you turn the socket to the right place. And here's the tricky part: It doesnt come out of the housing, it will actually go back into the housing, so you will need a screwdriver in the other hole to put pressure on the socket while you put the bulb in and twist the socket back into the lock position.
Seems that once you twist it, the bulb will come out, but otherwise the bulb is locked in. Ahh modern technology huh? Really should get me a pair of needle nosed pliers...
Give it a try let me know how it goes.
