1 - 9 of 9 Posts
I am considering installing a lift kit on my 2020 Compass Trailhawk. I have been getting used to things like adaptive cruise control, automatic steering, parking sensors, etc. I'm wondering if going up 2-4 inches will cause these tech features to not work as reliably because the sensors are now raised up as well. Is there any word from Jeep on this? Anyone get a lift and notice differences in car behavior from these systems?
Every time someone asks, I start feeling like a broken record. Oh well..... I have had the ATP 2.0" lift on my 2019 compass since maybe mile 3k. Not one problem. Ride, stability, traction control is the same. No worries what so ever. Toss on a size or two bigger tire and you’ll be one heck of a happy camper. I was. Still am...
I'm considering the ATP 2.0 as well. Did you have to buy additional parts to make it work?
Negative. The kit is all inclusive and strait fwd. I only had to use a good amount of locktite on the sway bar link bolts and re-tighten once. Those dried up river beds I like to travel down loosened up the nuts. It feels really solid and stable on the road and off road. Even at highway speeds it’s nice. From what I read on the other kits that need more attention or modifications, I think I got the winning combo with the ATP kit and Pirelli scorpion AT-plus tires. It does everything I needed it to do.
This is the exact combo I want. How long have you had it?
What size tire did you end up going with? And what psi you run them on road and off road?
I’ve had it for a year and a half. (20k miles) tires are 225R-17s. Any larger and I think the spring seat on the shocks will rub without adding spacers. Besides, I don’t want to do any trimming or big mods, just to fit tires. I do 38 psi on road and 20 psi off-road. I think it puts the ride height (about 11") at a real comfortable position and a good visual stance. Definitely gave me way more confidence as far as ground clearance is concerned.
is this kit a spacer kit only or your changed the coils as well?
2021 Jeep Compass Trailhawk
Lots of other threads on this I am sure you will lose MPG as well as void the warranty in certain areas.
1 - 9 of 9 Posts
