I installed the following LED bulbs for my 2018 Compass:
Low Beams: Sealight H11/H8/H9 LED Headlight Bulbs
https://www.amazon.com/gp/product/B07Q24LVDM/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1)
High Beams: Auxito 9005 LED Headlight Bulbs 12,000 LM per set 6500K
https://www.amazon.com/gp/product/B07WMG43QJ/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1)
DRLs: Auxlight 2504 PSX24W 12275 LED Fog Light Bulbs 6000K Xenon White, Super bright 2800 LM
https://www.amazon.com/gp/product/B07ZGPH4JN/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1)
My own experience is that unless you have hands the size of an infant, changing the low beam headlights is an experience in patience. In the end, I found that completely removing the plastic front fender liner and turning the wheels gives you the best chance of getting your hand up there, as well as reaching down from the engine compartment at the same time with your other hand. Of course, you can't see anything, but easy to feel your way around. FCA also skimped on the length of the wire harness for each headlight bulb to add to the fun. But easy to twist-out bulbs counterclockwise from housing once you can position your hand(s) correctly.
I was very impressed with the contents of the above Sealight kit - includes white cloth gloves, cable ties and adhesive strip for resistor box (not that I used either.) Sealight bulb kit also had long length of wire, not just the bulb like Auxito 9005 high beam, but everything tucks inside headlamp housing. However, Auxito bulb has built-in fan, which may be a plus for longevity.
Although install of Auxito high beams was a snap, I thought that due to bulb length, it barely fit behind dust cap on driver's side. I would have tried the Sealight brand, but was uncertain if their bulbs would fit inside housing / clear dust cap, as it appeared the Sealight 9005 bulbs (at least in Amazon product photo) had the connector coming straight out, not an "L-shaped" bulb with connector on side as Auxito's did. Plus Auxito bulbs supposedly had higher specs in LM's output.
After installation, no errors or flickering with any of above bulbs. Think low beams are much brighter than original halogens, and provide great "road coverage" from light beam output. So much, that I don't really see much of a difference between low beams and high beams anymore with these LED's.
