Hello,
Does any one know how to remove the caps on the back of the side mirrors?
I have not done it myself yet, but from what I have seen from pictures online it looks like you have to you a pry tool around the edges. It should pop out as normal.
I did some researching online and found that it's easier to remove the glass first. After the glass is removed, it's easier to get to the tabs that hold the cap in place. I found the following guide on a Cherokee forum and figured it would be similar: https://jeepcherokeeclub.com/4-2014-jeep-cherokee-general-discussion/237566-replace-side-mirror-caps.html.
I tried this on my Compass and found it to be the exact same procedure: Carefully remove the glass, and then release the tabs inside while using a pry tool to gently to get the cap off.
