1 - 10 of 10 Posts
hello all,
i have a 2007 compass atx with 180 000km
everything seem ok but i cant start the engin.the starter wont turn it do nothing.
do you have a idea please ?
thank you
i have some check engin code:
p0320 ignition/distributor
p0500 speed sensor
p0138 o2 sensor
p0700 transmission system
Could be the main relay shot.
I don't know but this might help. This site has a major restriction on file sizes for uploads. Screen shot of key areas to test. Note a relay is involved !!
this main relay it is inside of the fusebox ?
because i have change entire box .
thank you
The main box in front of the Computer is call the TIPM and some fuses and relays are inside. The other controls are solid stand and not serviceable. You should have a item assignment in you manual and underside of the TIPM cover.
Rust is a big problem on these early years especially. Make sure all the ground straps have clean contacts at their mount points.
Mine had the same problem, wouldn't start but there was power. It happened to be the starter relay, my mechanic fixed it by installing a better relay then the garbage that dodge uses. He said it's fairly common with compasses. Funny how when I called dodge they told me to bring it in because my car is still under warranty, after they looked at it they determined that this was not a warranty issue and wanted to charge me 400-500 for it. When I told him to piss up a rope they wanted to charge me for diagnostics on it. Long story short I didnt pay diagnostics, had to tow my car back to my mechanic to fix it which I should have done in the first place since he is down the road from my house... Thanks Dodge
Well it'll be clear what you won't buy next time. Manufacturers pay millions and millions of dollars on advertising. But they miss the boat on the value of The Word of Mouth. Customer satisfaction.
Oh well, I guess the marketing people make a good case but sales drop off and long time customers go elsewhere. They had enough.
Discussion Starter #7 (Edited)
hello all,
i have found the probleme is very commun.
it is the relay box front left of the jeep.
look at this :
i have 5 cable disconected....
where i can find the wiring diagram because i dont know where to re plug the cable.
or good picture of good relay box.
your help is very appreciate.
thank for all
Oh wow, that looks like its under the fender area. It should be in the hood area. I'll look for in later. Drivers side I expect.
Discussion Starter #9 (Edited)
yes driver side,
jeep put a big big hole where all the water come from the wheel to go inside and splash all wiring and relay box on the car.this hole is made to broke our car to make cash... GRRRRRRRRRRRRRRR
you need to patch this hole with urethane to prevent this probleme
Discussion Starter #10
Voila Jeep repaired. :)
big thank to all people have read or reply to my problem.
Good bye
i see you for the next problem ;)
1 - 10 of 10 Posts
