HELLO ALL
JUST GOT THIS NICE 2008 FOR MY DAUGHTER AND I NOTICED THERE IS A SMALL QUARTER SIZE HOLE IN THE SIDE OF THE CONSOLE THAT LOOKS LIKE IT HAS A SMALL LEVER. DOES ANYONE KNOW WHAT THAT IS OR DOES? OR IS THER A COVER FOR IT?
Also please dont yell....All caps is just rude...
Besides my Compass I've got a 2014 Patriot with the same console. There's a blank disk covering that hole on my Patriot. It's about the right size for an auxiliary outlet.
You've gotten me curious. Found on page 233 of the owners manual (OMs very useful documents) one finds this note. think that's the answer
NOTE: If a malfunction occurs, the transaxle will not
shift out of park. Battery power is required to release the
brake/transmission interlock system. There is a removable
plug in the right side of the shifter housing
that
allows you to insert your finger to override the system.
The key must be in the ignition and in the on position to
use the override lever. If this occurs obtain service as
soon as possible.
