1 - 20 of 23 Posts
Just got my 15" MB Chaos 5 Wheels with 235/75/15 Wrangler Territory tires...
Had to weight on getting new rims and got 235/65/17 Kumho AT2 tyhey work very well when I need new tires that's when ill be getting me some 15" rims and some good AT tires good to know that 15" is possible
235/65/17 is a good size, I've ran that size.
There is only a few models of 15" wheels that will fit on the compass.
Those look great!! I just got my 2015 4x4 trailrated compass and I like it so far. Why did you go and change the tires, because that's what I want now but I have to wait until I ware these out. You Suck and I mean that respectfully.
ya I took ur advised and the jeep looks so much better with the lift and the tire size wouldn't go any higher tho lol then ill have rubbing bad lol but what brand of 15 would work since u say only a few will work
Changed the tires, because I offroad lots, and the factory tires are not aggressive enough for any serious offroading.
It does great in the mud and snow now.
Looks Great
Hope you don't mind a couple questions?
Any rub?
Wheel spacers?
Offset on the Chaos wheels?
This is close to the same setup my son wants to do with his compass.
Thanks
Discussion Starter #11
They have noticeably more noise than factory tires, it's to be expected with the tread design. I have added additional sound proofing (Before I ran these tires) so the noise isn't all that bothersome.
No rub at all (I have done the pinch weld mod) but that wouldn't have to be done anyways
No spacers
0 offset
Wheel Details - Discount Tire Direct
Thanks
He is torn between those and Rage R5 (cheaper). The offset on them is 38 or 40. What effect would that have?
I think he has decided on General Grabber AT2 tires in the same size as yours.
You do have that Jeep looking very good.
Discussion Starter #14
That small piece of plastic has a metal part that sticks out underneath, with larger tires it will rub when they are turned.
You can't just run any 15" wheel, only the wheels mentioned in this thread will work
15" Wheels and 30" tires on your Patriot (no spacers): Test Fit Results - Jeep Patriot Forums
The 38mm and 40mm offset means the wheel sits closer to the body of the vehicle, so running larger (or wider than stock tires) will not work as they will rub without using spacers.
the 0 offset bring the wheel farther away from the body like a spacer but is safer than using a spacer.
Again thanks
Tried to do a little more research today. Understand the offset more now.
Think this is his setup:
RRO lift
MB TKO wheels: 15 X7 5-114.30 0 BKMTXX
General Grabber AT/2: LT235 /75 R15 104S C1
I think this will work without any other modification-your thoughts?
I am sorry for so many questions but he doesn't have money to waste on wrong decisions. High school with 3 sports and a job.
Discussion Starter #16
Yup, that should work if he's lifted he shouldn't have any problem.
Wow, looks amazing! Makes it look really aggressive and mean, the lift also really suits the tires as well. Congrats on the great purchase.
1 - 20 of 23 Posts
