1 - 15 of 15 Posts
Friday I was driving home from work when suddenly a loud "ding", then the service engine light came on and the traction control/stability light came on. The engine raced for a fraction of a second. This all happened while driving 30 MPH. It was a handful to drive while limping towards the Jeep dealer. It was low on power and fought itself driving down the road as if it was locked in 4x4 on concrete. Upon arrival at the Jeep dealer the service attendant connected a scanner and it said it was a battery problem. He then said call Monday and we will try to get it in next week. (not impressed) I told him I will take it home, disconnect the battery to clear the computer. He said, " DO NOT EVER DISCONNECT THE BATTERY!!! There are three computers that are extremely sensitive to voltage spikes". I then told him I really don't want to own a vehicle that is that fragile. Got home and discovered the dealer had installed a new battery two weeks before my purchase and they did not tighten the clamps. The battery tested okay so I reconnected and tightened the very cheap and weak battery terminal clamps. Everything has worked fine so far.
2015 Jeep Compass Latitude 4x4
980 miles, 26 MPG combined (light on the pedal)
I've disconnected my battery many times, haven't had any issues doing that.
same here changed my battery ones (wife left lights on in cold weather and killed it completely) then took off again when installed trailer wire harness and then again when I installed my spot light set up you just have to know what ur doing not hung them up back wards or don't jump ur jeep with jump cables back wards I'm a mechanic in the military and mess with batteries all the time
NOT FIXED YET! Same thing happened again driving home from work today. Limped to the dealer and they told me it would be two weeks before I could get it in. The same dealer owns all the Jeep dealers in town and they are all booked solid for two weeks. I found a dealer in another city that would take it right away. They also offered me a rental car unlike the dealer I purchased the Jeep from. Oh, and I discovered my second key is not a match. The dealer gave me a key to another Jeep.
Hey SPD KILS,
TSB 18-070-14 may relate to your vehicle:
SUBJECT:
Flash: MIL Illumination, P219A, P050B And Cold Start Improvements
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the Powertrain Control
Module (PCM) with new software.
MODELS:
2015 (MK) Jeep Compass/Patriot
NOTE: This bulletin applies to vehicles built on or before November 3, 2014 (MDH
1103XX).
SYMPTOM/CONDITION:
Some customers may see erroneous illuminated malfunction indicator lamps (MIL) and
have a hard start cold condition.
· P219A Bank 1 Air Fuel Ratio Imbalance
· P050B Cold Start Ignition Timing Performance
Let me know if you have any further questions.
I think it was built in November 2014. I need to check the exact date. Thanks
I don't use my vehicles to jump start others who's batteries are weak. There are too many sensitive components and the alternator is low powered on these as well. I have booster pack for that purpose should I need it myself. Far far safer and not surges or rectifier blowing boost loads for those who run their engine while boosting another vehicle. A very bad move which could blow your alternator or worst.
I wonder what is causing your problem on this new Compass.
I get the feeling when they disconnect the battery it will clear the code like it did for me and not act up again for the dealer. They will return it saying its fixed. It will only break down again. I don't have much confidence in these Jeep/Chrysler dealers because of the way I've been treated. It looks like every time it breaks down it will be a two to three week wait to get it in for repair. I usually own Chevy or GMC and have never had to wait for warranty repairs. I like the Compass and I hope I don't have to dump it due to fear of poor dealer warranty service or the lemon law. I also don't know how long I can stand driving the 2015 Camaro rental car full of cat hair and bad odor.
Rental vehicles don't have pets in them. Tell them its affecting you allergies if needed. Better go back to the rental agency you used. Just like non smoking vehicles here.
Fill or rather add a signature so the details and location etc. All guess work in that regard in these posts.
As for delayed service either take it to another dealer and/or call customer service and complain about your warranty service and poor service on a repeated problem. If you return it several times with the same problem they may have to buy it back unfixed.
Normally its policy you get a similar vehicle in a rental not a car for an SUV etc.
Discussion Starter #10
I purchased the Jeep in Omaha, Nebraska. I had to take it to a small town dealer in Blair Nebraska. The Jeep/Chrysler dealers in Omaha have become a monopoly. I believe our states lemon law says if they can't fix the same problem after three trips you can file. The dealer has an Enterprise rental office in their service bay. All they had was a Chrysler 200 and a Camaro.
All dealers were booked for two weeks. The out of town dealer said they were booked for three weeks but if I bring it in today they will squeeze it in the next 1 to 4 days. I said what? My choice it 3 weeks or 1 to 4 days??? I'll take 1 to four days. I will keep you posted.
Log the problem with Chrysler. Get a case number and they will escalate the issue with the dealer of your choice. Even send a specialist down for that appointment time. Otherwise your post will go without sympathy here. You have the time make the call and be clear and detailed on problem specifics for the log. Related work order would also help.
Good luck
Discussion Starter #12
Good point.
Well they said its a camshaft sensor and they hope to have one by tomorrow.
Kind of funny. I was in a company vehicle (2010 Ford Transit) in the middle of nowhere. Hundreds of miles from any large city when the camshaft sensor went out. I was able to find one in another state and have it delivered to NAPA in the next small town the following day. Repaired it in the parking lot. Its taking the Jeep dealer at least a week to do the same thing!
Discussion Starter #13
Got the Jeep back and it lasted almost a day and 80 miles before it broke down again for the third time. Another slow 25 mile trip to the Jeep dealer.:mad:
Discussion Starter #14
Got the Jeep back from the dealer again. Their test drive was 249 miles!!! Food and wrappers, mess in the interior. My opinion now... Jeep/Chrysler dealers suck!
Lol
1 - 15 of 15 Posts
