Caring for the Jeep and other cars
Hello Tonyotis. Here is a copy of my earlier post for Kay20. Pls read. Later on I will tell you how to locate noises and get rid of them. I did hear about some people having problem with the ball joints in this car. Some don't last more than 70 thousand miles. Fortunately I know what to do. My car now has over 110000 miles on it and the suspension is still great.
Here's the problem with the suspension and this is true with other makes also not only Jeep.
The new ball joints are sealed and they use a hard plastic "cage" for the "ball" and put very little moly grease. With millions of cars on the road they save money doing this but unfortunately it costs the motorists lots of money in parts and of course... labor. The solution is to add grease to the ball joints even the smaller ball joints they use on the anti-sway bar.
A grease gun fitted with a needle will be the best way. Do not worry about the grease leaking out. It won't. Water will not get in nor dirt as long as you put enough grease into it. You will see the rubber cup bulge out a little bit. This is good. Most importantly use the right grease! I recommend Castrol Pyroplex Blue. This is used in many heavy duty road building equipment and is guaranteed to perform well in any weather condition. As far as the smaller ball joints for the anti-sway bar, there are two for each wheel front and back.
Another important thing is that the inner tie rod joint actually wear out the fastest. So if any of the suspension ball joints are worn this inner tie rod joint will be too. Grease the outer tie rod joints also using this method. As for the inner tie rod joint. Remove the clip that holds the bellows and inject the grease through the space between it and the rod. Inject about 5 spoonfuls of grease for each side. The grease will reach the joint when you steer the car. You will enjoy a longer suspension life and nice quiet ride. No more clunking from the joints.
NOTICE: THIS WORK REQUIRES REMOVING THE WHEELS (FOR ACCESS) AND THEREFORE THE CAR HAS TO BE RAISED SAFELY WITH A GOOD RELIABLE JACK AND JACK STANDS. IF YOU CANNOT DO THIS WORK HAVE A MECHANIC OR SOMEONE FAMILIAR WITH THIS TYPE OF WORK DO IT FOR YOU. I HAVE MANY OTHER TIPS WHICH I WILL POST SOON. TKS
