Hi I'm Brandon from Columbia, Sc and I'm the owner of a 2008 Jeep compass. I'm have a probleme with the driver's side door which wont close completely. Any help would be appreciated.
Hi Brandon, I'm new also I seen you didn't have a response and I happen to have a little experience with doors over the years and also when I worked at a dealership. Is your door actually latching but sticking out of line with the body or is it not latching? if it is latching it is probably just in need of adjustment where the stryker meets the latch or worse case scenario the door could be sprung at the hinge or out of shape. If it's just in need of adjustment you could probably do the adjustments it will have some screws you can loosen and reposition the latch or any good body shop could realign it for you. Hope this helps
Dave
