1 - 1 of 1 Posts
2016 Compass Latitude, 4wd, 60k mi. Got it used. It's started doing the no start thing. Turn key, no cranking, no turnover.
I've narrowed it down to if it doesn't do anything when the key is turned, wiggle the shifter in the park position then it'll start after that. So far it's worked the last 3 times it didn't start so I'm guessing it's time to check the shifter bushings.
If that doesn't fix it, is there a sensor on the transmission side that could be going bad and can it be replaced by a weekend mechanic?
Nick
1 - 1 of 1 Posts
