Official Jeep Compass Recall Thread
18223 Views 7 Replies 5 Participants Last post by  LarryD
Post all the Jeep Compass Recalls in this thread.
This post will be updated as recalls come out.
2011+ Jeep Compass:
(none)
2007-2010 Jeep Compass:
1. NHTSA Campaign ID number : 06V434000 - ISSUE: MANUAL DOES NOT CONTAIN ALL INFORMATION ABOUT ROLLOVERS
2. Recall Number K11 - ISSUE: STICKY GAS PEDAL
3. 2011 Jeep Compass Steering Columns
Make / Models : Model/Build Years: JEEP / COMPASS 2007
Manufacturer : DAIMLERCHRYSLER CORPORATION
NHTSA CAMPAIGN ID Number : 06V434000 Mfg's Report Date : NOV 08, 2006
Component: EQUIPMENT:OTHER:OWNERS/SERVICE/OTHER MANUAL
Potential Number Of Units Affected : 18245
Summary:
ON CERTAIN SPORT UTILITY VEHICLES, THE OWNER'S MANUAL DOES NOT CONTAIN THE REQUIRED HIGHER ROLLOVER RISK WARNING INFORMATION.
Consequence:
WITHOUT THE ROLLOVER WARNING INFORMATION IN THE OWNER'S MANUAL, DRIVERS MAY NOT BE AWARE OF THE SIGNIFICANTLY HIGHER ROLLOVER RATE ON THIS TYPE VEHICLE, WHICH COULD RESULT IN A CRASH.
Remedy:
DAIMLERCHRYSLER WILL MAIL AN ADDENDUM TO THE OWNER'S MANUAL TO ALL AFFECTED VEHICLE OWNERS. THE RECALL IS EXPECTED TO BEGIN ON NOVEMBER 13, 2006. OWNERS MAY CONTACT DAIMLERCHRYSLER AT 1-800-853-1403.
Notes:
DAIMLERCHRYSLER RECALL NO. F03. CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION?S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
See less See more
This issue has spawned a recall (number K11).
2007 (PM) Dodge Caliber
2007 (MK) Jeep® Compass
NOTE: This recall applies only to the above vehicles equipped with an automatic
transmission (sales code DAV) and built from March 7, 2006 through May 19, 2006
(MDH 030706 through 051921).
The accelerator pedal on about 24,800 of the above vehicles may stick during vehicle
operation. This could cause the vehicle to react differently than the driver anticipated.
This could cause a crash without warning.
SPECIAL NOTE: All involved vehicles are equipped with an Electronic Throttle
Control (ETC) system that utilizes “Smart Pedal” technology that allows a brake
pedal input to override the throttle control system.
See less See more
Recall Central: Porsche 911 Lug Nuts; Chrysler, Dodge, Jeep Steering Columns
2011 Chrysler 200, Town & Country, Dodge Avenger, Caliber Grand Caravan, Journey, Jeep Compass, Patriot, Liberty, Wrangler
The Problem: 2011 Chrysler 200, 200 Convertible, and Town & Country, 2011 Dodge Avenger, Caliber, Grand Caravan, and Journey, and 2011 Jeep Compass, Patriot, Liberty, and Wrangler vehicles are all being recalled for a missing or incorrectly installed steering column pivot rivet. The missing or incorrectly installed rivet could lead to a loss of steering control, and potentially lead to a crash.
The Fix: Dealers will inspect to see if the rivet was installed, check the alignment of the column, and repair the steering column as necessary at no charge. Owners will be contacted starting this month, and can call Chrysler at 1-800-853-1403 or the National Highway Traffic Safety Administration’s hotline at 1-888-327-4236 in reference to Chrysler’s safety recall number L23.
Number of Vehicles Potentially Affected: 11,351 2011 Chrysler 200, Chrysler 200 Convertible, and Town & Country, 2011 Dodge Avenger, Caliber, Grand Caravan, and Journey, and 2011 Jeep Compass, Patriot, Liberty, and Wrangler vehicles.
NOTE: Only models affecting between production dates of April and May 2011
Article Found At: Recall Central: Porsche 911 Lug Nuts; Chrysler, Dodge, Jeep Steering Columns - Rumor Central
See less See more
wow!! compassmike.. your really in to it... good for you!!!
New to group here's my compass 2012 limited fully loaded
See less See more
Has anyone done yet S61 recall affecting 2011-2014 Compass?
Occupant Restraint Control (OCR) Module
https://www.chrysler.com/universal/webselfservice/pdf/S61.pdf
What about the rusty cross bars on engine support?
Originally Posted by JeepCares View Post
I am sorry to hear about your recent experience with your Compass. I would advise you to bring TSB 23-012-14 to the attention of your servicing FCA dealership.
SUBJECT:
Front And Rear Crossmember Corrosion (X58 10 Years Unlimited Mileage)
OVERVIEW:
This bulletin involves inspecting the front and rear crossmembers for perforation / rust
through and if necessary, replace the crossmember(s).
MODELS:
2007 PM Caliber
2007 MK Compass, Patriot
NOTE: This bulletin applies to vehicles built on or after August 26, 2005 (MDH
0826XX) and on or before July 23, 2007 (MDH 0723XX).
SYMPTOM/CONDITION:
The customer may describe a vibration at the steering wheel or may have been informed
by a technician or state vehicle inspection that the front and / or rear crossmember is
severely corroded.
See less See more
