41 - 60 of 65 Posts
I don't see "window visors" on it at all. What am I missing????
Look at the black Compass above posted by @katrinacop. It has black window visors. I'm curious where they came from too
Discussion Starter #46 (Edited)
5mm spacers didn't work so now I'm going to try these .75 inch. I got these from quadratec
Discussion Starter #48
I put 3" adapter spacers on mine if you guys want to see lol, rubs a little with the stock tires.
Have you been in for any dealer service since having them? Did they say anything about them?
Discussion Starter #50
Cherokee wheels
17x7
5x110
41mm
Continental TerrainContact A/T tires
225/60/17
Had to use .75 inch spacers to clear front caliper. Put them on front and rear
Looks awesome, glad you were able finally find the correct spacer. It really looks outstanding.
Discussion Starter #52
Discussion Starter #53
I didn't think to take pics of the spacer until I was on the last rear wheel. Here's some pics nonetheless. I also removed the tire repair kit and put the factory 18" wheel in for a spare. I feel much better knowing my wife has a spare available to her now.
not yet, i plan to take it to the dealer for the 2nd oil change and inspection (updates and stuff) but i dont see where it would be a problem, ive installed an air intake, 1.5" teraflex lift and a pedal commander (the intake made it loud AF after 4k RPM)
225/65/R17 No rubbing.
Hey Guys,
I know that this is an old thread, Sorry in advance.
For any of you running tires taller than 28"
Like 225/65R17= 28.5x8.9R17
Or 215/70R17 = 28.9x8.5R17
I am really curious about how much room you have left before the spring perch on the front. When i look at 10-64's close up of his front wheel, it looks like there is a bit of room. -But- that is a Trailhawk, and I'm wondering if something is different. You guys have the same type of room. I'd like go 235/65/17.
Thanks,
Rob
Others who have actually done it will chime in soon but AFAIK you just need ~1+ inch spacers to fit that tire. There will not be much clearance to things like the spring perch and fender liners, possibility of a little rub here and there, but several people here seem to get by with it. RadRacer uses 1.5 inch sapcers:
Wheel Spacers on 2018 Trailhawk
I’m surprised that I haven’t see others go a bit wider either. Anyone know of, say, 255/55/17 ?
I’ve got a set of Cherokee Trailhawk rims, since the backspace helps, I’d consider trying it. If I can snatch a straggler off of Craigslist or something, I’ll check it out.
41 - 60 of 65 Posts
