1 - 18 of 18 Posts
I went into work early this moring and did my second oil change 5521 miles and rotates the tires. I was making my service book and noticed they want the air filter replaced at 12,000 miles. Has anyone put a K&N drop in filter in and know the part # for a 2.4L? I'm using Castrol 5W-20 for now but will go to Synthetic after 10,000 miles.
Not sure of the part number but I put a drop in filter in mine after the first 5000km. It did make a very tiny improvement in MPG but the biggest gain in throttle response and it appears a little more powerful. Nothing to peel the paint off but I noticed it especially pulling my pop up trailer. Plus the added bonus of never having to change an air filter again. I clean mine once a year as I don't drive off road.
Good luck
PS Syntec is very good. If you are near a Costco up here in Canada its only 47 bucks to have them change it surely its cheaper south of the border as most things tend to be.
Wes
I say what ???? excuse my ignorance but what is a drop in filter ?
Just returned from a long week of driving and returned directly from Montreal. I noticed when I was their I had 5000km since I changed it last. It must be close to 6k on it now and the indicator to change has not come on. Dahhh way too long for my liking.
Dealers want $8 for the Mopar filter after market seams to be hitting the same point for poor brands even at part stores. Wix is pricey but are they better than the OEM. If I have to pay that I might just as well use the Mopar. Chysler cannot say I am using an inferior filter down the road.
I went to NAPA and picked up there Napa Select filter. I just finished the oil change and will change it again in about 5k km or less. Their Gold filter is twice the $$$ and maybe for the winter when there is more crud buildup from cold starts etc.
You were in Mtrl and didn't tell me ?????
We could have met somewhere................tell next time maybe we can hook up. Makes beautiful pictue for the forum...... :)
Manual says 10000k between changes, I do mine at 5000km as well and get it done at costco for 49 bucks with castrol syntec.
it's a synthetic oil. The big draw is that it doesn't break down as quickly as conventional oil. There is some leakage problem with synthetic sometimes because it will swell the seals differently than conventional oils but that can be remedied by adding a quart of conventional oil to the synthetic each change.
i switched mine over to the mobil 1 when i did the brake caliper painting, and i must say i was a little dissapointed that i couldnt find a mobil 1 filter for this engine. so i got old faithful fram with the grippy end.
whats the preffered brand of oil filter on the forum?
While any oil changed is better than no or too long an interval. Fram is the same boat. Better than nothing. I used a NAPA filter on my last change & there is a NAPA Gold but just under $10 which is about the same as the Mopar price.
A filter is a filter is a filter. Actually, a generic filter is better than an advertized brand name. Wal-Mart filters are for the most part better at filtering than STP or Fram. Look it up yourself!
Just gonna throw my two cents in here. I change my oil every 4,000 miles and use Valvoline fully sythetic oil. I don't worry about filters either. Whatever is cheap and looks good. On my old car I did the same and had that damn thing at 60,000 - 150,000 miles with no problems at all. So hopefully the Jeep will do the same (Started at 26,000).
I guess that also depends on how good this 2.4 block is. I had not heard of it before not that I was checking. It has enough HP for my uses and more than the much bigger Caravan I sold after getting this.
All right everyone get ready now.
1
2
3
Change your Oil and fluids, go go.. quickly change it!!
Fram uses cardboard in the filters that could breakdown and be pulled into the motor. Found that out looking it up myself.
I use WIX filters on the other two cars and I got Mobil 1 synthetic oil 5W 20 & a Mobil filter from Advance Auto. It was on sale for $40 and was for 5 quarts so I got some extra.
Don't know about the air filter...but one note on synthetic it burns faster but is worth the extra cost
Burns faster? Clarify, you have to add oil? If so it too then a getting by somewhere. 5w20 is already very thin I would go with 5w30 in synthetic at minimum. I am currently running that in Dino oil (Quaker State).
What make of Synthetic are you using and grade?
1 - 18 of 18 Posts
