1 - 13 of 13 Posts
so i had my first oil change at @ 5k
now 3k later, its saying i need another
905 highway driving.
is there soemthing that needs to be reset when you get an oil change?
Page 107 of the owner's manual:
• Your vehicle is equipped with an engine oil change
indicator system. The “Oil Change Due” message will
display in the instrument cluster display for five seconds
after a single chime has sounded, to indicate the next
scheduled oil change interval. The engine oil change
indicator system is duty cycle based, which means the
engine oil change interval may fluctuate, dependent
upon your personal driving style.
• Unless reset, this message will continue to display each
time the ignition is cycled to the ON/RUN position.
• To reset the oil change indicator after performing the
scheduled maintenance, refer to the following procedure.
Models Equipped With Keyless Enter-N-Go — Ignition
1. Without pushing the brake pedal, push the ENGINE
START/STOP button and cycle the ignition to the ON/
RUN position (do not start the engine).
2. Fully push the accelerator pedal, slowly, three times
within ten seconds.
3. Cycle the ignition to the OFF/LOCK position.
NOTE: If the indicator message illuminates when you
start the vehicle, the oil change indicator system did not
reset. If necessary, repeat this procedure.
within ten seconds.
so that means i dont need one? have to see if the mechanic reset it when he did the oil change
Depends on if it was rested in the first place or not. If not, the system is assuming you didn't change the oil for 8K miles, so it would be normal.
talked to mechanic, he normally resets them, but says it doesnt always take.
edit: the messege was not on there when i took it in @ 5k. so he had no way to know if it reset or not
My first two oil change messages were just shy of 8 thousand miles each, I'm guessing that trend will continue so I am doing an oil change WITHOUT reset at 4k miles in between the ones the computer calls for and so far that is working out pretty good for me, but I am the type of personality who is always watching the odometer and thinking about when the next oil change interval will come up. If you aren't that kind of person all you need to do is simply drive it until it says "give me an oil change" and everything will be fine.
i usually do changed @ 5k since i drive highway miles
why? you go longer without changing if you do highway miles
The reason why yours came on after the change is because you got the oil changed too early, and they didn't reset it. If you waited until the indicator comes on then you should be OK and the mechanics will see the indicator and remember to do the steps to reset it.
I used to do 5k with conventional oil, now with all cars switching to synthetics I will go 7k+
my wife's vehicle does not commute so it's much less highway driving and we change hers around 5k just because it sits for so long.
Discussion Starter #9
i know i can go longer than 5k, but my brain just wont let me
i consider it cheap peace of mind
i only pay @ $35 for a change.
given i drive @ 30k a year thats only $210 a year
I changed the oil in my '18 Compass 6 speed manual for the first time @ 5500 miles since the indicator had never come on (with full synthetic) and obviously there was nothing to reset. At 11000 miles and still no indicator I changed it again, and again obviously no indicator to reset (and full synthetic once again with 1 quart of Lucas). Now, at 13000 miles the "oil change required indicator" has finally come on. Should I really believe that my oil needs changing with just 2000 miles on it, or just ignore the indicator and wait until 16500 as I had planned at my normal 5500 mile synthetic interval? Is it possible that the higher viscosity Lucas supplement may be throwing off the sensor?
There is no sensor, it is a duty based system. Since you never reset the system after an oil change, it is just showing up the 1st oil change.
What kind of additive are you using? I wouldn't use any additive or different viscosity oil with this type of engine that uses oil as hydraulic fluid.
The only thing I'd put Lucas anything in is something that had a noise and I was trying to quiet it down to sell. Never would I let that stuff anywhere near a car I planned to keep.
1 - 13 of 13 Posts
