What are some other Jeep model rims (all the Cherokee models) that will "simply bolt onto" my 2nd gen, 2018 Compass Sport w stock 16" rims or will all 2nd gen models like the limited or trail hawk simply bolt on? I'm thinking yes except for 4WD models as the hubs must be different. Any thoughts? I'm like most guys, I want an 18" tire with an AT tire to make it look bolder. I'm looking at a good chunk of change going with what I can be sure will fit (after market): BLACK RHINO - WARLORD Matte Black with Dark Tint Edge (18" x 8", +35 Offset, 5x110 Bolt Pattern, 72.1mm Hub) more details on - https://www.carid.com/black-rhino-wheels/warlord-1890war126140m12-n-81423853.html and Yokohama GEOLANDAR A/T G015 - SIZE: 225/55R18 https://www.tirerack.com/tires/tires.jsp?tireMake=Yokohama&tireModel=Geolandar+A/T+G015&partnum=255HR8G015
Thanks all...
wish I could tell you - ours came with 225/55/R18 off the bat....
You can use 16, 17 or 18” rims from The Renegade, Compass or the Cherokee. Understand that if you use the Cherokee rims you will need wheel spacers (@3mm) on the front wheels as the calipers stick farther out on a Compass than they do on a Cherokee. No interference problems with the rear using Cherokee wheels.
  • Like
Reactions: arudlang
I have the Cherokee Trailhawk rims on my Compass, and did not need spacers. Clearance is fine.
Also keep in mind the Fiat 500x wheels will fit. Replace fiat center cap with Jeep one n done.
I put on black rhino Barstow 18x8 with Falken Wildpeak AT 225/55/18. I think I could have run a little taller and wider but with the rim increase the tire shop said no.
