Has anyone removed this? I was trying to take me dash apart to get access to the 3.5 speaker region in the dash but couldn't remove the connector on the passenger airbag.
Does it just pull off? Is there a locked clip?
Do i have to worry about it going off even when the battery is disconnected?
Thanks guys
If the battery is disconnected you should be good to go. For extra comfort you could always remove the fuse for it.
Not too sure about the clip though as I've never taken one apart.
Let us know how that airbag removal works out for you. Hopefully nothing set it off. More concerned about proper installation after it has been removed.
