The other day my friend told me that he had to change the pcv valve on his Mazda MPV. His car is almost as old as mine. Mine, a 2007 Jeep Compass.
So I thought about checking my pcv valve. I found a youtube video on how to replace it. Simple task... so I decided to check my pcv valve today. To my surprise it was still very clean. No sign of sludge or anything like that at all. Perhaps my use of synthetic oil and regular cleanings of the air filter helped it keep clean all this time. My car now has 122000 miles. Still in great condition.
I guess using the right lube and cleaning helps a lot in maintaining and prolonging the life of the engine.
buy a new pcv they are under 30$ and compare them....
PCV valve is a very simple part but sticking is the biggest issue which can occur when slugged or filled with contaminents. If when you shake it the piston rattles back and forth then there is nothing wrong with its.
