Hello All,
2007 Jeep Compass Sport 2.4L, 178,000 miles
Let me begin by saying thank you to anyone who tries to help me with this. Between myself and my mechanic (who has been able to fix any issue I've ever brought him with any vehicle) we have not been able to fix this.
Issue 1: Air conditioner only blows REALLY cold when you are driving down the road.
Issue 2: There is a vibration when in drive and at idle. Vibration does not happen when in park, neutral, or reverse.
Issue 3: While at idle, (red light, stop sign, drive thru, it doesn't matter) it acts like it wants to die but not so much so that it actually does. The RPMs do fluctuate low when it does
this and when you hit the gas it hesitates a couple of times as you're going. When you're actually driving, there is no issue.
Issue 4: Not throwing any codes. At all. None.
Steps taken so far to repair:
1: Motor mounts replaced
2: Spark plugs and coil packs replaced (gapped as they should be)
3: Air filters replaced at every oil change and bought new ones and replaced them just in case.
4: Throttle body removed, cleaned, and replaced.
5: Fuel injector cleaner added to full tank and driven to empty.
And yes, I'm aware what's been done is the bare minimum so please don't judge. We have not done any more than that because we are both absolutely flummoxed as to what could be causing it without a code being thrown. He said at this point it is just a guess, check, and replace until we've found the issue. Hence why I am here. I would like the opinions of people smarter than me so that as we are doing the guess, check, and replace I'm not spending a ton of money on things that may not be an actual issue.
Again, thank you to everyone who tries to help. I know without it throwing a code it's going to be a huge guessing game.
