1 - 1 of 1 Posts
hey guys I'm going to be installing a temporary 2ch amp for the 8s I put in until I can afford the 6ch's that I need I was wondering how much wire I need to go from battery, along drivers fender, across motor, thru washer fluid grommet, down and along door/floor under passenger seat. its been raining all day so I couldn't go out with a rope to check.
also if you have run 1/0 what path did you take, I'm hoping I can go thru on passengers side thru the frame/fender skin like the stock wire loom does on the driver's side also if you knew how much length you used to go to the spare that would be great.
1 - 1 of 1 Posts
