Hi all. I have a 2015 compass high altitude. A week ago I noticed the radiator fan running over an hour after turning the car off. The only way to turn it off (short of disconnecting the battery) is to remove the 40 amp fan relay. I've swapped the relay and even tried disconnecting the wires from the coolant temperature sensor, but the fan still runs. Does anyone know if there is another temp sensor or fan controller that could be causing this issue? Many thanks in advance for any help you can provide.
