1 - 12 of 12 Posts
Hey All,
I've searched to the best of my ability but can't seem to find an issue that matches mine.
2007 Compass, 2.4L, 2WD, 5-Speed, Sport, 73,xxx miles. (White, just in case that matters:))
The issue that I'm experiencing is that once the vehicle is warmed up to normal operating temp, usually after 10 minutes or so, there is a thump/rattle (not tinny like a heat shield) that sounds like it's coming from the middle/rear of the car.
Once I'm on the highway and can get the car into 4th or 5th gear and put a decent load on the engine, at approximately 3000-3500 RPM the thump/rattle turns into a howl/resonance type sound.
Above and below that RPM range the noise starts to decline and any bumps in the road cause the thump/rattle regardless of RPM.
My local Jeep dealer looked at it yesterday and said that the Front Torque Support is bent and causing the noise, then they happily charged me $79 for the honor of putting it on their lift without driving it.
The check engine light hasn't been on and it a passed the annual emissions inspection.
With the car on ramps in my garage last night I saw that there is a "ding" in the Torque Support but it's NOT bent.
When I questioned the service writer, he just said, "Well, that's a problem, so fix that first and then we'll look at it again."
I won't go into detail about my opinion that there seems to be an emerging trend...the decline of mechanics and rise of "part swappers."
So, with all of that being said, I expect that the problem is in the exhaust system, (catalytic converter is my prime suspect) what do you all think?
Thanks in advance!
Jeff
I'd put my best assessment that the catalytic converter has a separated shield/plate loose inside. Get under and hit it and see if you get any rattling (be sure its cooled down) you can use your fist or something that won't bend/dent it.
Discussion Starter · #3 ·
Thanks, tripplec!
With the car back on the ramps today, I first used my gloved fist to bang up and down the exhaust system after it had cooled down and when I couldn't produce a rattle I switched to a rubber mallet; still no rattle.
Since it only makes the noises when it's at normal operating temp, I took it for a drive and after the noises showed up, I banged on it again with fist and mallet but still couldn't hear any rattling.
I convinced a service writer at the dealership to take a ride with me. He was skeptical at first, and when the first thumps started, he said it was a bad strut...I politely persisted that it wasn't, that I think it's something in the exhaust, and asked if he'd mind taking it on the highway to demonstrate the drone/resonance sound.
4th gear on the highway, right in the sweet-spot of 3000-3500 RPM, the noise kicks in. "Hmmm, sounds like something in the exhaust. Probably a lose mount." I tell him again that I don't think it is, and that the hangers are all intact and there's no noise when shaking the exhaust from underneath.
Back at the dealership, he grabs the HOT tailpipe and burns his hand, gets a rag, and while still cussing his burned hand, he shakes the exhaust. "Well, it doesn't make any noise when I shake it and the hangers all look good...I'm stumped."
My next appointment is Monday morning to have a tech look at it again. I'll post back with an update afterwards.
Jeff
Well clearly he was just guessing without foundation. Strut noises come from the front and rarely on the highway. City bumps and speed bumps reveal those issues.
Clearly he's in need of the basics and started in the School of Hard Knocks !!! Not to grab a hot exhaust is or appears his first lesson, many more to come to become wise in the ways of cars. LOL :rotfl:
Odd it did not show up knocking under the exhaust though. Muffler and/or converter to me expecially since you get the howl from the exhaust which appears as if something is not where it should be inside.
Hey All,
Thanks in advance!
Jeff
Hi Jeff,
Did you ever find out what was wrong, cause I'm having the same problem?
Thanks
James
Discussion Starter · #6 ·
Hi Jeff,
Thanks
James
Hey James. I sort of stumbled across what I think was the problem while I was fixing some rust in the passenger side rear wheel arch. I bumped the heat shield on top of the muffler and it was totally loose. Not really thinking, I just reached in and yanked it out...of course being barely more than aluminum foil, it crumpled into an unrecognizable pile and I promptly tossed it in the trash can.
I sold the car shortly after that but in the few weeks that I drove it the noise never came back.
Hey Jeff,
appreciate your response awesome I will have a look at the heat shield.
many thanks
James
Hey Jeff, removed the heat shield but rattling still there so I replaced rear muffler now no more rattling!! Yeah!!! According to muffler guy there’s a inner plate in muffler when car warms up it loosens inside and starts to rattle!!
Discussion Starter · #10 ·
Thanks for following up to let us know what it was! Hopefully it'll help someone else, too.
1 - 12 of 12 Posts
