1 - 9 of 9 Posts
Anyone know how to take apart the black plastic surround that is between the rear view mirror and windshield? I need to get to the wiring so I can tap into the 12v and ground for my radar detector and driving cam. I know it comes apart in half but don't want to break it. Only have 200 miles on it so I don't want to brake something already ha. Thank you.
-Frank
It's $15 from the dealer if you break it, I just used a plastic pry tool and split the halves. Didn't break anything, nothing much back there anyways. I prefer using an add-a-fuse and 12v to USB cord (from Amazon) under dash, up A pillar, across headliner and back down behind the cover is how the power wire for my dash cam is ran.
I have a post with pictures, specifically for the a pillar due to there being an airbag behind it, you don't want to just stuff the wire behind the plastic, I zip tied mine to the rear washer fluid hose that way it's safe and out of the way.
Oops.................I just tucked the dash cam wire in behind it cover, up the A frame and across the top of the windshield. Ya, I knew there was an airbag in there. Thats why I didn't push the wire in too far, or with anything metallic. (BOOM!)
Thanks for information.
This camera uses the OBD to get power. It's normal 12V outlet (you could also use the cigarette lighter to get power for the cam).
1 - 9 of 9 Posts
