I have a new 2020 Compass. Is there a rear window washer Reservoir? I can't find it if there is.....can't find it in the owner's manual n either. Thank you.
There is only one reservoir (under the hood), it is used for both the front and rear.
Ditto gerogef and 10-64. Why do you ask? Is it not working? Could be frozen. Happens to mine a lot. I don't use it much and my reservoir is mostly the summer stuff with only some winter stuff added. If temp drops below zero F or even into the single numbers, the line will freeze. Rather than purging the whole system I just add some alcohol to the reservoir.
I don't know where you live but even the -20F fluid isn't always enough around here, especially considering as I just said, adding good juice just gets dilluted by the summer stuff already in the reservoir.
