1 - 20 of 33 Posts
I found something out today I thought I would share as it might help others in the future. We took our Trailhawk to the service department this morning to get the hitch and trailer wiring installed. We got a call a little after 3pm to tell us they ran into an issue and had to order a new bumper or lower bumper fascia it will be in tomorrow and they did offer a loaner car. We have 3 other vehicles here at home so I told them for just keeping it another day we did not need the loaner.
Being curious and always wanting to learn something new to help myself and others I talked to the service manager to see what was going on. He told me the hitch did not come with a template to cut the bumper for the trim insert. When he pulled up the install information it said they could no longer cut out the bumper and a new fascia designed for the hitch was required. It appears the new fascia has special clips installed to hold the trim insert in place. I can only guess that the trim insert was falling out on people.
So for those that are thinking about a DIY install of the Jeep Compass factory style hitch keep this in mind. If you choose to not order a new fascia for the hitch then look the trim insert over really well and consider some type of modification that will better hold that piece in place. Also if you plan to have the service dept install the hitch you need to bring this up to them so they can give you the price for replacing that fascia. I have no idea how much that cost as I had in in our contract that the dealer would install the hitch and wiring as part of our deal.
Our Compass is a Trailhawk but I can only guess this hold true for all trims.
I saw that as I was going to tackle this for a DIY. Not a big deal mopar parts has the trim for 99 bucks. OEM of course
No it is not a huge deal but something I thought everyone should be aware of. Getting stalled in the middle of fixing or upgrading something because of a change in the install process and having to wait on parts you didn't know you needed is always a bit of a pain.
Well another day and more hitch hang ups. It seems the techs thought they needed to program the wiring harness to work as has been done with other Jeeps. They inserted the program and my Jeep went haywire on them tossing a bunch of trouble codes. They called Jeep head honchos and they told them they used the wrong code remove it then insert a code they gave to them. Once done the Compass kicked out a whole new bunch of trouble codes. Then it was discovered that no they should not have touched the computer for this wiring harness.
So they went back to the factory default programming. Then surprise surprise more trouble codes but a lot less of them and suddenly these codes are not even related to any of the other codes or the trailer light harness they are codes for the parking brake. This lead them to the ABS module which does not even show up in the computer. So they are thinking the ABS module actually failed and was not exactly right from the factory. I'm starting to wonder if with all the programming if the thing did not just brick on them. We will know more tomorrow.
So if your adding a trailer wiring harness to the new Compass it does not appear to need to be programed into the computer and if your having it done tell the sevice dept. to not touch the computer if they insist have them call it in to the head techs at Jeep first! Got to love sometimes having the newest version of something! LOL
Hitch saga finely over Compass is back home now. The final issue with the ABS turned out to be they nicked a wire when drilling the hole in the firewall for the trailer wiring. They actually had to pull everything back apart to trace their steps. But all is well now hitch looks great just like a factory install. They even detailed the Jeep back out as a way to say sorry it took so long. We love having our little Compass back!
Congrats Chris, how bout pictures & part #
Around how much did the install cost you? I called my local Jeep dealership, and was given a quote of $1800
called around and found a dealership that will do it for $300 labor, about $510 for the fascia, hitch, and wiring harness
I'll try to pull that together tomorrow and get some pics. It looks just like the factory installed hitch and comes out of the lower bumper fascia so nothing hanging down under the bumper messing with your departure angle. It is really nice and I like it a lot.
Discussion Starter #9
When we were just looking at this compass I knew we had to have at least the hitch on it for our bike rack. I went into the sevice department and ask for a price on hitch. I almost fell over they quoted almost $600 and that is before they knew they had to replace the lower fascia as they were no longer allowed to cut the hole in the non-hitch fascia and that is basically another 100 bucks or so. This is just for the hitch not the wiring. The wiring is another 200+ bucks and 2-3 hours of labor after the price on the hitch I did not ask about cost of wiring.
We continued working the price with the dealer. We had found a Trailhawk with a hitch about an hour or so away but our local dealer beat the price by enough to cover the hitch and then some. But then that dealer sent an email asking if we were still looking. We told him we were near pulling the trigger on a Jeep that was closer and cheaper. He then cut his price to beat this one the only difference is the one an hour way had the hitch and this one had no hitch but navigation. I told my salesman I was going to go look at the other one because it has the hitch that we needed.
I barely got off the lot when we got a call from the local dealer they matched the price and agreed to install the factory style hitch and wiring harness. At that point we just pulled the trigger on it as I had driven it and checked it all out for the known issues like the messed up dash dimming. So long story short I did not pay for it so I don't know what the cost for everything was. I can tell you it took 3 extra days for them to figure out the wiring and computer and they had to buy that fascia!
If I had to bet around $1000 to $1200 for the hitch,wiring, and fascia. I pretty penny for what is like a $400 factory option on the Trailhawk and I think $700-$800 on the other trims!
I think if your handy you could buy the hitch and fascia and install it yourself. It looks like you simple pull the bottom bumper fascia off. Then remove the rear impact bar and install the hitch in place of the impact bar then install the hitch type fascia and your done.
The wiring gets crazy for the factory set up as it has to run all the way to the fuse box under the hood then over to the passenger side relays behind the glove box. That is a lot of interior trim to deal with. I did see some aftermarket wiring that claims to work with the 2nd gen that is way cheaper and might be simpler to run. However I worry as sensitive as these things are it might throw codes.
On your lower estimate make sure they are talking about the lower bumper fascia and not just the face/trim plate that comes with the hitch. If so I think that is a good deal but try to get something that locks them into that price. I hate to guess even for the dealership what it cost for a tech to spend bacilly 3 1/2 days figuring out all the hang ups on mine! :)
I was quoted today for a Factory hitch installation for my 18 Compass TH, $512
Factory Hitch - $512
Window Tint for Driver and Passenger windows - $259
The hitch would be factory installed. The Rock Rails and the lift would also be aftermarket as well but unfortunately they are currently not available. The window tint is aftermarket. Please let me know if you have any questions or if you would like to see when you could get an appointment scheduled.
Tint seems a bit high on cost for 2 windows?
I don't think she knows about rock road outfitters or Teraflex
Discussion Starter #11
I have not had a chance to take pics but on Google you can do an image search for Jeep Compass factory trailer hitch and several will show up.
For part numbers I dug up some links on Mopar parts for 2018 Compass Trailhawk if you have a none Trailhawk you can go to mopar parts and find what you need. Pay attention to rear fascia as the selections will determine not only hitch but reverse sensors as well. Again you might be able to cut your stock fascia and make it work. But the service dept. told me the hitch no longer ships with the bumper template to show you where to cut the fascia. If you go this route check to see if you need to better secure that hitch trim!
https://www.moparpartscorp.com/oem-parts/mopar-tow-hitch-receiver-82215105/?c=Zz1oYXVsaW5nJnM9dG93aW5nJmE9amVlcCZvPWNvbXBhc3MmeT0yMDE4JnQ9dHJhaWxoYXdrJmU9Mi00bC1sNC1nYXM=
https://www.moparpartscorp.com/oem-parts/mopar-trailer-tow-wiring-harness-82214670ab/?c=Zz1oYXVsaW5nJnM9dG93aW5nJmE9amVlcCZvPWNvbXBhc3MmeT0yMDE4JnQ9dHJhaWxoYXdrJmU9Mi00bC1sNC1nYXM=
https://www.moparpartscorp.com/oem-parts/mopar-fascia-rear-lower-68352701ab/?c=Zz1ib2R5JnM9YnVtcGVyLWFuZC1jb21wb25lbnRzLXJlYXImaT1XQzE3NjU1NSZyPTUmYT1qZWVwJm89Y29tcGFzcyZ5PTIwMTgmdD10cmFpbGhhd2smZT0yLTRsLWw0LWdhcw==
https://www.moparpartscorp.com/oem-parts/mopar-lower-cover-68352700aa/?c=Zz1ib2R5JnM9YnVtcGVyLWFuZC1jb21wb25lbnRzLXJlYXImaT1XQzE3NjU1NSZyPTUmYT1qZWVwJm89Y29tcGFzcyZ5PTIwMTgmdD10cmFpbGhhd2smZT0yLTRsLWw0LWdhcw==
So I setup the appointment to have my hitch installed while out of town. I get a call saying that they need to order the part as none are available locally. I said np. I then get a call on my way home from trip and the dealer is saying they didn't factor in the new requirements for hitch installation. Meaning they didn't really researched the cost of said hitch. Original quote was 512 installed, they now saying its going to be 748 installed, due to fact they have to replace the lower facia. Should I stick to the original quoted price? or try to meet them in the middle?
When I dropped it off I brought up the fact that they had to replace lower facia and not do cutting. and quoted price was stated.
Just a question, is it too big of a DIY job? I mean it is only 8 nuts, replacing the lower fascia and splicing into the wiring. I have never installed a receiver so I am just asking.
I had to purchase 3 parts, the fascia, the hitch, and the wiring harness, which was about 550 after tax. That's why I've been so surprised by people saying they were quoted <$600. I still haven't gotten mine installed yet, parts are supposed to be in on Monday, so I'll get it installed on Tuesday, hopefully the original $300 labor quote is still accurate.
Discussion Starter #15
Yes installing the hitch having the right parts from the get go would not be that bad of a job. The wiring is another issue. These vehicles have a link to the bulbs and splicing into the system causes codes. This is why they run the wiring up to the front fuse box. So the load of the trailer lights is not seen by the computer.
When I was looking into this I did find a wiring harness by Curt I think it was that they claimed will work and had an isolation module that required a hot to be run up to the battery. It was not near as expensive and looked like a simpler install. My concern is that when looking at parts and accessories some manufactures had not yet picked up on the fact that the 17.5 and up Jeep Compass are a completely different vehicle than the older ones. So if you go this route I would contact the maker and make sure they know this!
FYI
I just installed the open hitch kit on my 2017 Trailhawk.
I used the lower fascia part with the backup sensors... very easy, super clean install
I did notice that the factory lower fascia has the cutout template etched into the inside of it... but those slots to cut out are really small... but for those wanting to save some money and are good with a dremmel, the template is already there
One note, the instructions were wrong in several places, but it was obvious what needed to be done.
I made sure when I purchased my Trailhawk that it had the factory installed trailer hitch. Not only is the factory hitch thru the rear fascia of the bumper, it also has a transmission cooler AND additional engine cooling! That to me was a "no brainer". Get the factory one, NOT an aftermarket hitch.
I saw a lot of Trailhawks that I liked when I was looking but the one I wanted needed to have a "factory hitch"
I know this isn't going to help anyone that already owns a Trailhawk, BUT, if you're looking for one, get the factory hitch!
Looking at the cost for all the parts, to do this aftermarket, it's costing you way more than factory, and you're still out the transmission cooler and additional engine cooling!
Discussion Starter #18
Out of curiosity do you have a link that shows the tow package has a trans cooler and more engine cooling? All I ever found on the tow package stated hitch and wiring for the Trailhawk and adds a full size spare to other trims.
I have discussed this with the dealer. There is no additional cooling of any kind with the factory hitch. Someone lied to you
Hmmmm, that's what they told me here.
It does have, as an "option" the code "NHAP" Engine Oil Cooler, ?? Is it possible that the 2017's options came packaged differently??
This vehicle was ordered in as a "Loaded" demo, with every possible option, for demo purposes
1 - 20 of 33 Posts
