1 - 20 of 21 Posts
I can't seem to help myself when it comes to modifying my cars. I don't do much performance mods, but I do alot of retrofitting of options, and even adding options that did not exist for my cars. Call it a hobby, as I enjoy doing it. If curious about whether I have any clue as to what I'm talking about, look me up on TheMustangSource or Rennlist.
Well, there are options that the Compass in North America doesn't have that everybody else does that I am looking into retrofitting, such as:
power folding mirrors with puddle lights
Adaptive Cruise Control
Self Park
LED head lights
LED tail lights
8 way Power passenger seat
Driver memory seat
Rear fog lights
Just looking into the feasibility of these things.
Since my Trailhawk has the front collision sensor, rear park sensors and blind spot sensors, I suspect I have everything already needed for ACC and self park. Others are already looking into getting the AlfaOBD to access modules and turn stuff on , so I think there is a good chance that this can be done.
As for parts for these things, this is what I have so far:
55112714 AE and 55112715 AE - Front LED headlights
55112684 AB and 55112685 AB and 55112680 AD and 55112681 AD - rear LED tail lights
68365164 AA and 68365165 AA - power folding mirrors with puddle/courtesy lights
6BZ32LXH AA or 5YAP70DX9 AB - switch for folding the mirrors
Looking to see if there is a module for ACC and Self Park, but I can't find anything. I'm using the VIN form an Australian Compass Trailhawk to dig for part numbers.
If anyone can add to this or correct me if I have wrong info?
Thank you!! I assume we will get the VIN numbers and part numbers for ACC when 2019 Compasses with ACC start to roll out in US.
Others have suggested that the ACC module is not a separate module, but that ACC is part of the cruise control function and the front sensor. Can't find anything, though.
Yeah I think the ACC module is a part of the radar. It is called the ACC sensor module.
https://www.ebay.com/itm/Adaptive-Speed-Cruise-Control-Sensor-Module-NEW-OEM-2014-2015-Grand-Cherokee-/272995850016
Here is some more info from dodge challenger forum;
https://www.challengertalk.com/forums/f314/adding-adaptive-cruise-control-after-purchase-difficult-expensive-415562/index2.html
The software is in the eyeball itself and whatever else is needed in the car is already in every car.
As far as hardware goes, all you would need to do is add the eyeball and the buttons. You could tap the cable harnesses in yourself, eyeball needs power, ground, and CAN+/-, so there are many points where you could tap in under the hood. I'm pretty sure the buttons would work with your existing wheel hardware.
After that, you'd need to flash the ACC into the BCM and go through the alignment procedure. You'd need to find somoene with the right scan tool, or a very sympathetic dealership. Perhaps it could be baked into the Tazer firmware, as it certainly is capable of doing so. If enough people asked, it might happen.​
based on this, I think the only parts that US compasses with front collision warning and breaking need is the cruise control switch assembly with the ACC related buttons. With that, you can swap out the regular cruise control switch with that one and if it can hopefully be activated softwarewise, it should work.
That's the assumption. Hopefully someone with AlfaOBD can tell us. When I downloaded the AlfaOBD demo, it did show ACC as a separate module. You would need to turn it on in the ECU and the cluster, and maybe the ABS module? And then make sure the modules can still talk to each other.
LED headlights/taillights are available in North America. At least in the US I know for sure. I'm an Audi guy so I appreciate the euro headlights with no amber reflector, but if you're just looking for the LED DRL strip in the headlight (and taillights), it is an option here in the US on the Limited models.
Discussion Starter #9
Oh really? For 2018, I could not get it for a Trailhawk, but I didn't look at Limiteds. I'll have to look closer to home.
I also see that ACC is now an option on 2019 Limiteds in Canada.
Yep, check out the Limited. I'm looking at the Jeep website and It's part of the Advanced Safety & Lighting Group. It will say 'Bi-Xenon HID Headlamps with LED Signature'
Unfortunately on the other models, the Advanced Safety & Lighting Group will only give you Bi-Xenon HID Headlamps without the LED strip.
Why are the US version so skimpy on options at the dealership. My "LIMITED" comes with no option and have so many blank covers where all the cool stuff are supposed to be. Just a reminder for me that LIMITED just means BASIC.
Hmm, what are your sources of information on the parts needed for the ACC upgrade? I have a newly acquired (brand new, but sat on the dealer lot for over 18 months) 2017 Compass MP Latitude with the Advanced Safety group and I'm also a tinkerer. I just ordered the parts to add a factory tow package to my Compass (looks so much better than the aftermarket packages) and I'm currently wiring together a full interior ambient lighting kit including perimeter uplights around the edges of the panoramic sunroof (in tests, it looks really freaking cool).
I'd love to upgrade the cruise control system to make use of ACC, and it looks like I should already have the sensors and radar needed to do it. But just adding the switches seems...too easy. There has to be more to it than that.
You need to software activate it. That is the most difficult part.
My previous car (a Subaru) had a freely available software package called FreeSSM that gave you access to all of the computer settings, and my daughters Prius has a publicly available package called Techstream that does the same thing, allowing full access to the internal CANBUS and computers. I'm new to Jeep (and FCA vehicles in general)...does anything similar exist for the Compass, or are we forced to grovel to the dealerships for software tweaks?
There is a program called alfaobd that can do it. However, FCA installs security modules to their cars that prevents saving changes done by non-service authorized devices. So making changes and saving them requires installing a security bypass module.
I am into retrofitting as well. So I will keep an eye on this for the more simple things like a rear fog light. I am going aftermarket on the headlamps as I have stated in the mods section of the forums. I am thinking that is going to be a hard one when the bi-xenon is one bulb for high and low beams, from a dual system of high and low beams. I am sure it is doable, but I will wait till someone else try with that... Chopping up the harness to make that possible seems scary in such a new SUV.
anyway, cool stuff in this thread will sub to it watch it grow :)
I have a 2018 compass and mine does not have the security module installed. I can use alfaobd to enable / disable things, clear codes, etc. I'm just waiting on a fix for the proxy alignment so I can complete my mods.
Keep us posted. You have access to the ACC then?
My Jeep doesn't have the radar 'eye', so I'd have to add it first. If someone has an automatic with the safety and security package, alfaobd demo, and OBD adapter, they can try connecting to the ACC module.
1 - 20 of 21 Posts
