1 - 10 of 10 Posts
Do any other rims fit our 2018 Compasseseseseseseesssses? Such as other Jeep OEM rims like Wranglers, etc. Or do any truck rims fit? When I go to a site like tirerack.com and pull up rims for my model it pretty much gives me rims that fit on cars. Be great to know of alternatives that have a wider stance and black truck rims.
I would love to know this as well.
Also, does anyone have a definitive answer as to what our hub bore is? My google search has shown two different results.
The Renegade/new Compass/Cherokee/Fiat 500X are all 5x100 65.1 CB. If a site is saying 67.1 for a Compass they just haven't updated their info from the old Mitsu based model.
5x100 is really a car size so no surprise you are seeing 'car' wheels. If you are looking for used wheels maybe look for Subies.
CB really only matters in that the wheel 'hole' needs to be at least 65.1 mm. Larger CB is okay within reason.
Some wheels are available as 'blanks'. You would need to confirm with the manufacturer and get them drilled to 5x100, but it's a possibility.
http://www.kmcwheels.com/wheel/32318/xd827-rs3
XD82778000520 is a 17x8 blank.
Here is the information you need.
http://www.myjeepcompass.com/forums/2nd-gen-jeep-compass-forum-general-discussion/34153-2nd-gen-trailhawk-stock-wheel-size.html
http://www.myjeepcompass.com/forums/2nd-gen-jeep-compass-photos-videos/40625-spring-cleaned-up.html
Bolt pattern is 5x110
Stock Trailhawk Wheel size is 17x6.5 with offset of 40mm
I did measure the center hub bore also, it was 65.1mm
The only true Jeep family wheels that will fit are some off the new style Cherokees and Renegades but you have to keep the offset between 35 and 40. To the best of my knowledge.
Hope this answers your questions.
isnt it 5x110?
Not 5x100..
Thanks for confirming. I'm only concerned with the CB because I'd like to order hub centric wheel spacers, and I need to know the correct size. I know when it comes to aftermarket wheels I would just run a hub ring to take care of a larger wheel CB.
Thank you for the info! This is exactly what I needed from someone who's actually measured it.
1 - 10 of 10 Posts
