Trick Allen Key for the Cross Rails
When you attach the cross rails to the roof rails they are locked in place with a allen key supplied. It has a hole in the end which allows it to fit over a small stud in the bolt hole.
DO NOT LOOSE THIS KEY!
I put mine in some safe place, so safe not even I can find it.
Now I cannot reposition the rails.
I have tried a couple of dealers, the first had to be convinced that the rails were not just locked with the key also used. Then suggested I have a machine shop modify a standard allen key.
The second suggested I (somehow) break off the small stud in the center of the bolt hole. Now how would one go about that???
You would think it would be available by order through the MOPAR system.
