I just bought xm radio snap and i got got to pass the wire antenna trought my engine bay for install the magnet on the roof of my compass. So any hole for have access trought my engine bay? tx
there should be a grommet where the clutch is supposed to go. you could use that. or just attach the wire to a metal hanger and push it through where the rest of the wires are going through the firewall.
you should peel the weather stripping away from the door and run the cable behind that. the constant closing of the door over that wire is going to wear a hole in the antenna. i'd also look into doing a more permanent installation, that looks a bit sloppy and will catch on things and rip wires out over time. just my opinion.
