I have a 2008 Jeep Compass Sport. Everytime i try to start the car it takes 2 or 3 times to finally start. After that i have no problems the rest of the day. Its only when the car hasnt been running for a few hours that this happens. Also my check engine light is on. Can anyone help me with this problem?
Maybe neet to check the check valve in the fuel pump. Probably this is leaking and pressure drops when the truck is parked. or have a leaking inyector (i hope not to happen this).
regards,
Any way you can get a code pulled?
2008 MK P2004 and P2017 codes
Yeah i got the codes and they are P2017 and P2004
Here’s information from the 2008 MK Service Manual about those codes:
P2004-INTAKE MANIFOLD RUNNER CONTROL STUCK OPEN
When Monitored:
With the engine running, when the valve closes, below a calibrated RPM, depending upon pedal position.
Set Condition:
The Powertrain Control Module (PCM) detects that the position feedback of the Manifold Flow Valve Position Sensor is not within range of the adapted value learned during in-plant initialization or after a non volatile memory reset (adaptive memory clear).
Possible Causes
(K857) 5-VOLT SUPPLY CIRCUIT SHORTED TO VOLTAGE
(K602) MFV SIGNAL CIRCUIT SHORTED TO VOLTAGE
(K857) 5-VOLT SUPPLY CIRCUIT SHORTED TO GROUND
(K602) MFV SIGNAL CIRCUIT SHORTED TO GROUND
(K857) 5-VOLT SUPPLY CIRCUIT SHORTED TO (K900) SENSOR GROUND CIRCUIT
(K602) MFV SIGNAL CIRCUIT SHORTED TO (K900) SENSOR GROUND CIRCUIT
(K602) MFV SIGNAL CIRCUIT SHORTED TO THE (K857) 5-VOLT SUPPLY CIRCUIT
(K857) 5-VOLT SUPPLY CIRCUIT OPEN OR HIGH RESISTANCE
(K602) MFV SIGNAL CIRCUIT OPEN OR HIGH RESISTANCE
(K900) SENSOR GROUND CIRCUIT OPEN OR HIGH RESISTANCE
(Z909) GROUND CIRCUIT OPEN OR HIGH RESISTANCE
MANIFOLD FLOW VALVE
INTAKE MANIFOLD
POWERTRAIN CONTROL MODULE (PCM)
P2017-INTAKE MANIFOLD RUNNER POSITION SENSOR CIRCUIT HIGH
When Monitored:
With the ignition on and battery voltage greater than 10.4 volts.
Set Condition:
The Powertrain Control Module (PCM) detects that the MFV Position Sensor input voltage is above the maximum acceptable value.
Possible Causes
(K857) 5 VOLT SUPPLY CIRCUIT SHORTED TO VOLTAGE
(K602) MFV SIGNAL CIRCUIT SHORTED TO THE (K857) 5 VOLT SUPPLY CIRCUIT
MANIFOLD FLOW VALVE
